[PATCH] user/start/bsp-test.rst: Changed bsp to erc32-sis.
Niteesh gsnb.gn at gmail.com
Tue Nov 19 17:26:26 UTC 2019
I actually google about the authorship stuff, do you want me to add the
--author command to the commit?
On Tue, Nov 19, 2019 at 10:55 PM Niteesh <gsnb.gn at gmail.com> wrote:
> I am new to this, so can you please elaborate on the steps.
> On Tue, Nov 19, 2019 at 10:16 PM Gedare Bloom <gedare at gwmail.gwu.edu>
> wrote:
>> Hi Niteesh,
>> Can you please provide a patch with your name on the authorship for
>> tracking copyright purpose?
>> On Mon, Nov 18, 2019, 2:29 AM <gsnb.gn at gmail.com> wrote:
>>> From: gs-niteesh <gsnb.gn at gmail.com>
>>> This commit (id=abc540105d10ddc9cad7de3c7ac0a9aa209ac828) removed
>>> the target sim from gdb, but the doc was not updated, so on running
>>> rtems test as per the doc caused failures, this commit changes it
>>> use the erc32-sis which used standalone sis simulator.
>>>  user/start/bsp-test.rst | 2 +-
>>>  1 file changed, 1 insertion(+), 1 deletion(-)
>>> diff --git a/user/start/bsp-test.rst b/user/start/bsp-test.rst
>>> index 5278375..8a14862 100644
>>> --- a/user/start/bsp-test.rst
>>> +++ b/user/start/bsp-test.rst
>>> @@ -21,7 +21,7 @@ Just run this command:
>>>  .. code-block:: none
>>>      cd $HOME/quick-start/build/b-erc32
>>> -    rtems-test --rtems-bsp=erc32
>>> --rtems-tools=$HOME/quick-start/rtems/5 .
>>> +    rtems-test --rtems-bsp=erc32-sis
>>>  This command should output something like this (omitted lines are
>>> denoted by
>>>  ...).  In this output the base directory :file:`$HOME/quick-start` was
>>> replaced
>>> 2.17.1
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191119/a6067fdc/attachment.html>
