[PATCH v2] tester: Add basic support to generate JUnit test reports
Chris Johns
chrisj at rtems.org
Wed Nov 20 22:37:34 UTC 2019
Looks good and thanks. There are some very minor formatting things, please push
with these fixed.
On 21/11/19 3:57 am, Hesham Almatary wrote:
> tester/rt/test.py | 52 ++++++++++++++++++++++++++++++++++++++++++++++-
> 1 file changed, 51 insertions(+), 1 deletion(-)
> diff --git a/tester/rt/test.py b/tester/rt/test.py
> index 3cd9b48..fded48c 100644
> --- a/tester/rt/test.py
> +++ b/tester/rt/test.py
> @@ -285,8 +285,58 @@ def generate_json_report(args, reports, start_time, end_time,
> json.dump(json_log, outfile, sort_keys=True, indent=4)
> +def generate_junit_report(args, reports, start_time, end_time,
> + total, junit_file):
> + from junit_xml import TestSuite, TestCase
> + import sys
> + junit_log = []
> + junit_prop = {}
> + junit_prop['Command Line'] = " ".join(args)
The code uses `'` and avoid `"`. This is done to allow `"` to be in a string.
There are a few spots below :)
> + junit_prop['Python'] = sys.version.replace('\n', '')
Is this always `\n` or is it os.linesep? I am not sure.
> + junit_prop['test_groups'] = []
> + junit_prop['Host'] = host.label(mode='all')
> + junit_prop['passed_count'] = reports.passed
> + junit_prop['failed_count'] = reports.failed
> + junit_prop['user-input_count'] = reports.user_input
> + junit_prop['expected-fail_count'] = reports.expected_fail
> + junit_prop['indeterminate_count'] = reports.indeterminate
> + junit_prop['benchmark_count'] = reports.benchmark
> + junit_prop['timeout_count'] = reports.timeouts
> + junit_prop['invalid_count'] = reports.invalids
> + junit_prop['wrong-version_count'] = reports.wrong_version
> + junit_prop['wrong-build_count'] = reports.wrong_build
> + junit_prop['wrong-tools_count'] = reports.wrong_tools
> + junit_prop['total_count'] = reports.total
> + time_delta = end_time - start_time
> + junit_prop['average_test_time'] = str(time_delta / total)
> + junit_prop['testing_time'] = str(time_delta)
> + for name in reports.results:
> + result_type = reports.results[name]['result']
> + test_parts = name.split("/")
> + test_category = test_parts[-2]
> + test_name = test_parts[-1]
> + junit_result = TestCase(test_name.split('.')[0])
> + junit_result.category = test_category
> + if result_type == "failed" or result_type == "timeout":
> + junit_result. add_failure_info(None, reports.results[name]["output"],
Space between . and 'add_..'.
result_type)
> + junit_log.append(junit_result)
> + ts = TestSuite("RTEMS Test Suite", junit_log)
> + ts.properties = junit_prop
> + ts.hostname = host.label(mode='all')
Spaces around `=`.
> + # write out junit log
> + with open(junit_file, 'w') as f:
> + TestSuite.to_file(f, [ts], prettyprint=True)
Again spaces.
> report_formatters = {
> - 'json': generate_json_report
> + 'json': generate_json_report,
> + 'junit': generate_junit_report
> 2.17.1
> devel mailing list
> devel at rtems.org
