[PATCH v2] tester: Add basic support to generate JUnit test reports
    Hesham Almatary
    hesham.almatary at cl.cam.ac.uk
    Thu Nov 21 10:30:38 UTC 2019
Hi Chris,
Thanks for your comments. I basically duplicated the code from
generate_json_report. I'll submit another version of the patch
addressing your comments.
On Wed, 20 Nov 2019 at 22:34, Chris Johns <chrisj at rtems.org> wrote:
> Looks good and thanks. There are some very minor formatting things, please push
> with these fixed.
> On 21/11/19 3:57 am, Hesham Almatary wrote:
> >  tester/rt/test.py | 52 ++++++++++++++++++++++++++++++++++++++++++++++-
> >  1 file changed, 51 insertions(+), 1 deletion(-)
> > diff --git a/tester/rt/test.py b/tester/rt/test.py
> > index 3cd9b48..fded48c 100644
> > --- a/tester/rt/test.py
> > +++ b/tester/rt/test.py
> > @@ -285,8 +285,58 @@ def generate_json_report(args, reports, start_time, end_time,
> >          json.dump(json_log, outfile, sort_keys=True, indent=4)
> > +def generate_junit_report(args, reports, start_time, end_time,
> > +                         total, junit_file):
> > +    from junit_xml import TestSuite, TestCase
> > +    import sys
> > +    junit_log = []
> > +    junit_prop = {}
> > +    junit_prop['Command Line'] = " ".join(args)
> The code uses `'` and avoid `"`. This is done to allow `"` to be in a string.
> There are a few spots below :)
Ok I replaced all `"` with `'`.
> > +    junit_prop['Python'] = sys.version.replace('\n', '')
> Is this always `\n` or is it os.linesep? I am not sure.
Not sure, I copied that from generate_json_report.
> > +    junit_prop['test_groups'] = []
> > +    junit_prop['Host'] = host.label(mode='all')
> > +    junit_prop['passed_count'] = reports.passed
> > +    junit_prop['failed_count'] = reports.failed
> > +    junit_prop['user-input_count'] = reports.user_input
> > +    junit_prop['expected-fail_count'] = reports.expected_fail
> > +    junit_prop['indeterminate_count'] = reports.indeterminate
> > +    junit_prop['benchmark_count'] = reports.benchmark
> > +    junit_prop['timeout_count'] = reports.timeouts
> > +    junit_prop['invalid_count'] = reports.invalids
> > +    junit_prop['wrong-version_count'] = reports.wrong_version
> > +    junit_prop['wrong-build_count'] = reports.wrong_build
> > +    junit_prop['wrong-tools_count'] = reports.wrong_tools
> > +    junit_prop['total_count'] = reports.total
> > +    time_delta = end_time - start_time
> > +    junit_prop['average_test_time'] = str(time_delta / total)
> > +    junit_prop['testing_time'] = str(time_delta)
> > +    for name in reports.results:
> > +        result_type = reports.results[name]['result']
> > +        test_parts = name.split("/")
> > +        test_category = test_parts[-2]
> > +        test_name = test_parts[-1]
> > +        junit_result = TestCase(test_name.split('.')[0])
> > +        junit_result.category = test_category
> > +        if result_type == "failed" or result_type == "timeout":
> > +            junit_result. add_failure_info(None, reports.results[name]["output"],
> Space between . and 'add_..'.
> result_type)
> > +        junit_log.append(junit_result)
> > +    ts = TestSuite("RTEMS Test Suite", junit_log)
> > +    ts.properties = junit_prop
> > +    ts.hostname = host.label(mode='all')
> Spaces around `=`.
> > +    # write out junit log
> > +    with open(junit_file, 'w') as f:
> > +        TestSuite.to_file(f, [ts], prettyprint=True)
> Again spaces.
> Chris
> >  report_formatters = {
> > -        'json': generate_json_report
> > +        'json': generate_json_report,
> > +        'junit': generate_junit_report
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
