[PATCH v3] tester: Add basic support to generate JUnit test reports
Hesham Almatary
Hesham.Almatary at cl.cam.ac.uk
Thu Nov 21 10:30:33 UTC 2019
tester/rt/test.py | 52 ++++++++++++++++++++++++++++++++++++++++++++++-
1 file changed, 51 insertions(+), 1 deletion(-)
diff --git a/tester/rt/test.py b/tester/rt/test.py
index 3cd9b48..6b45b78 100644
--- a/tester/rt/test.py
+++ b/tester/rt/test.py
@@ -285,8 +285,58 @@ def generate_json_report(args, reports, start_time, end_time,
json.dump(json_log, outfile, sort_keys=True, indent=4)
+def generate_junit_report(args, reports, start_time, end_time,
+ total, junit_file):
+ from junit_xml import TestSuite, TestCase
+ import sys
+ junit_log = []
+ junit_prop = {}
+ junit_prop['Command Line'] = ' '.join(args)
+ junit_prop['Python'] = sys.version.replace('\n', '')
+ junit_prop['test_groups'] = []
+ junit_prop['Host'] = host.label(mode = 'all')
+ junit_prop['passed_count'] = reports.passed
+ junit_prop['failed_count'] = reports.failed
+ junit_prop['user-input_count'] = reports.user_input
+ junit_prop['expected-fail_count'] = reports.expected_fail
+ junit_prop['indeterminate_count'] = reports.indeterminate
+ junit_prop['benchmark_count'] = reports.benchmark
+ junit_prop['timeout_count'] = reports.timeouts
+ junit_prop['invalid_count'] = reports.invalids
+ junit_prop['wrong-version_count'] = reports.wrong_version
+ junit_prop['wrong-build_count'] = reports.wrong_build
+ junit_prop['wrong-tools_count'] = reports.wrong_tools
+ junit_prop['total_count'] = reports.total
+ time_delta = end_time - start_time
+ junit_prop['average_test_time'] = str(time_delta / total)
+ junit_prop['testing_time'] = str(time_delta)
+ for name in reports.results:
+ result_type = reports.results[name]['result']
+ test_parts = name.split('/')
+ test_category = test_parts[-2]
+ test_name = test_parts[-1]
+ junit_result = TestCase(test_name.split('.')[0])
+ junit_result.category = test_category
+ if result_type == 'failed' or result_type == 'timeout':
+ junit_result.add_failure_info(None, reports.results[name]['output'], result_type)
+ junit_log.append(junit_result)
+ ts = TestSuite('RTEMS Test Suite', junit_log)
+ ts.properties = junit_prop
+ ts.hostname = host.label(mode = 'all')
+ # write out junit log
+ with open(junit_file, 'w') as f:
+ TestSuite.to_file(f, [ts], prettyprint = True)
report_formatters = {
- 'json': generate_json_report
+ 'json': generate_json_report,
+ 'junit': generate_junit_report
2.17.1
