[PATCH v3] tester: Add basic support to generate JUnit test reports
Thu Nov 21 23:13:37 UTC 2019
OK to push.
Thanks
On 21/11/19 9:30 pm, Hesham Almatary wrote:
>  tester/rt/test.py | 52 ++++++++++++++++++++++++++++++++++++++++++++++-
>  1 file changed, 51 insertions(+), 1 deletion(-)
> diff --git a/tester/rt/test.py b/tester/rt/test.py
> index 3cd9b48..6b45b78 100644
> --- a/tester/rt/test.py
> +++ b/tester/rt/test.py
> @@ -285,8 +285,58 @@ def generate_json_report(args, reports, start_time, end_time,
>          json.dump(json_log, outfile, sort_keys=True, indent=4)
> +def generate_junit_report(args, reports, start_time, end_time,
> +                         total, junit_file):
> +    from junit_xml import TestSuite, TestCase
> +    import sys
> +    junit_log = []
> +    junit_prop = {}
> +    junit_prop['Command Line'] = ' '.join(args)
> +    junit_prop['Python'] = sys.version.replace('\n', '')
> +    junit_prop['test_groups'] = []
> +    junit_prop['Host'] = host.label(mode = 'all')
> +    junit_prop['passed_count'] = reports.passed
> +    junit_prop['failed_count'] = reports.failed
> +    junit_prop['user-input_count'] = reports.user_input
> +    junit_prop['expected-fail_count'] = reports.expected_fail
> +    junit_prop['indeterminate_count'] = reports.indeterminate
> +    junit_prop['benchmark_count'] = reports.benchmark
> +    junit_prop['timeout_count'] = reports.timeouts
> +    junit_prop['invalid_count'] = reports.invalids
> +    junit_prop['wrong-version_count'] = reports.wrong_version
> +    junit_prop['wrong-build_count'] = reports.wrong_build
> +    junit_prop['wrong-tools_count'] = reports.wrong_tools
> +    junit_prop['total_count'] = reports.total
> +    time_delta = end_time - start_time
> +    junit_prop['average_test_time'] = str(time_delta / total)
> +    junit_prop['testing_time'] = str(time_delta)
> +    for name in reports.results:
> +        result_type = reports.results[name]['result']
> +        test_parts = name.split('/')
> +        test_category = test_parts[-2]
> +        test_name = test_parts[-1]
> +        junit_result = TestCase(test_name.split('.')[0])
> +        junit_result.category = test_category
> +        if result_type == 'failed' or result_type == 'timeout':
> +            junit_result.add_failure_info(None, reports.results[name]['output'], result_type)
> +        junit_log.append(junit_result)
> +    ts = TestSuite('RTEMS Test Suite', junit_log)
> +    ts.properties = junit_prop
> +    ts.hostname = host.label(mode = 'all')
> +    # write out junit log
> +    with open(junit_file, 'w') as f:
> +        TestSuite.to_file(f, [ts], prettyprint = True)
>  report_formatters = {
> -        'json': generate_json_report
> +        'json': generate_json_report,
> +        'junit': generate_junit_report
> 2.17.1
> devel mailing list
> devel at rtems.org
