no_cpu/no_bsp?
Fri Nov 22 06:56:51 UTC 2019
On 18/11/2019 15:28, Sebastian Huber wrote:
> Hello,
> should I add the no_cpu/no_bsp BSP to the new build system? It results
> in errors like this:
> ./waf bsp_defaults > bsps.ini
> Configure board support package (BSP)      : no_cpu/no_bsp
> Checking for program 'no_cpu-rtems5-gcc'   : not found
> Could not find the program ['no_cpu-rtems5-gcc']
> (complete log in /build/git-rtems-5/build/config.log)
If nobody objects, I will remove the build specification for the no_cpu
architecture.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
