no_cpu/no_bsp?
Chris Johns
chrisj at rtems.org
Fri Nov 22 10:33:06 UTC 2019
On 22/11/19 5:56 pm, Sebastian Huber wrote:
> On 18/11/2019 15:28, Sebastian Huber wrote:
>> Hello,
>> should I add the no_cpu/no_bsp BSP to the new build system? It results in
>> errors like this:
>> ./waf bsp_defaults > bsps.ini
>> Configure board support package (BSP) : no_cpu/no_bsp
>> Checking for program 'no_cpu-rtems5-gcc' : not found
>> Could not find the program ['no_cpu-rtems5-gcc']
>> (complete log in /build/git-rtems-5/build/config.log)
> If nobody objects, I will remove the build specification for the no_cpu
> architecture.
I have no objections.
