User manual and new build system
Fri Nov 22 14:25:26 UTC 2019
On Fri, Nov 22, 2019, 8:19 AM Sebastian Huber <
> Hello,
> I am about to add the documentation of the new build system to the user
> manual. There is no longer a bootstrap of the sources necessary. Should
> I remove all information for the bootstrapping from the user manual?
> Should there be a chapter for the old build system?
Don't remove the old process until the code is removed. I thought we had
agreed to a final autoconf based release. A release with both will help
ensure it is functionally equivalent and provide a baseline for comparison.
--joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191122/7edd4186/attachment.html>
