User manual and new build system
Fri Nov 22 14:31:40 UTC 2019
On 22/11/2019 15:25, Joel Sherrill wrote:
> On Fri, Nov 22, 2019, 8:19 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     Hello,
>     I am about to add the documentation of the new build system to the user
>     manual. There is no longer a bootstrap of the sources necessary. Should
>     I remove all information for the bootstrapping from the user manual?
>     Should there be a chapter for the old build system?
> Don't remove the old process until the code is removed. I thought we had
> agreed to a final autoconf based release. A release with both will help
> ensure it is functionally equivalent and provide a baseline for comparison.
I would remove the old build system as soon as possible. Shipping a
release with two build systems makes maintenance more difficult. Getting
rid of Automake/Autoconf would remove these packages from the RSB build
for example.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
