no_cpu/no_bsp?
Gedare Bloom
gedare at rtems.org
Sat Nov 23 18:35:35 UTC 2019
On Fri, Nov 22, 2019, 5:43 AM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Nov 22, 2019, 4:33 AM Chris Johns <chrisj at rtems.org> wrote:
>> On 22/11/19 5:56 pm, Sebastian Huber wrote:
>> > On 18/11/2019 15:28, Sebastian Huber wrote:
>> >> Hello,
>> >> should I add the no_cpu/no_bsp BSP to the new build system? It results
>> in
>> >> errors like this:
>> >> ./waf bsp_defaults > bsps.ini
>> >> Configure board support package (BSP) : no_cpu/no_bsp
>> >> Checking for program 'no_cpu-rtems5-gcc' : not found
>> >> Could not find the program ['no_cpu-rtems5-gcc']
>> >> (complete log in /build/git-rtems-5/build/config.log)
>> > If nobody objects, I will remove the build specification for the no_cpu
>> > architecture.
>> I have no objections.
> Agreed. It is supposed to be an example or template for a port.
We should migrate it to documentation. And any time a patch is changing all
bsps it should be checked with the example.
> --joel
>> Chris
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191123/0e2adaa5/attachment.html>
