no_cpu/no_bsp?
Joel Sherrill
joel at rtems.org
Fri Nov 22 12:42:36 UTC 2019
On Fri, Nov 22, 2019, 4:33 AM Chris Johns <chrisj at rtems.org> wrote:
> On 22/11/19 5:56 pm, Sebastian Huber wrote:
> > On 18/11/2019 15:28, Sebastian Huber wrote:
> >> Hello,
> >> should I add the no_cpu/no_bsp BSP to the new build system? It results
> in
> >> errors like this:
> >> ./waf bsp_defaults > bsps.ini
> >> Configure board support package (BSP) : no_cpu/no_bsp
> >> Checking for program 'no_cpu-rtems5-gcc' : not found
> >> Could not find the program ['no_cpu-rtems5-gcc']
> >> (complete log in /build/git-rtems-5/build/config.log)
> > If nobody objects, I will remove the build specification for the no_cpu
> > architecture.
> I have no objections.
Agreed. It is supposed to be an example or template for a port.
--joel
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191122/bb8d2136/attachment.html>
