New Build System Status
Mon Nov 25 21:05:34 UTC 2019
On Mon, Nov 25, 2019 at 2:12 AM Sebastian Huber <
> On 25/11/2019 08:55, Chris Johns wrote:
> > On 25/11/19 5:28 pm, Sebastian Huber wrote:
> >> On 24/11/2019 23:25, Chris Johns wrote:
> >>>>> Should there be a note or something about waf needing python and we
> recommend
> >>>>> python3? Plus waf needs a `python` installed and not just `python2`
> or
> >>>>> `python3`?
> >>>> I think this belongs to the Host Computer section. The quick start
> uses the
> >>>> RSB, so if you managed to build the tools, you must have a working
> Python.
> >>>> The RSB uses Python and the RTEMS Tools use waf.
> >>> The RSB can use python2 or python3 without a python. What about a note
> to say
> >>> ... "Waf uses python and you need to make this command available on
> your system".
> >> Now I am a bit confused. I thought every UNIX-like system provides a
> >> #!/usr/bin/env python
> >> which maps to Python 2 or 3?
> > Apparently on some distros the python executable is not automatically
> installed
> > with a suitable python2 or python3. I am not aware of the specifics of
> this but
> > it was raised as an issue that I fixed in the RSB:
> > https://devel.rtems.org/ticket/3537
> I have never seen a system in which
> #!/usr/bin/env python2
> or
> #!/usr/bin/env python3
> works, but not
> How many Python scripts would stop to work in this case? However, the
> availability of a python command is not mandatory according to:
> https://www.python.org/dev/peps/pep-0394/
> I think we should note in the "Host Computer" section that a "python"
> command is mandatory for RTEMS and remove the RSB extra stuff.
Chris can answer to that.
But on Centos 7, we have:
$ type python
python is /usr/bin/python
$ python --version
Python 2.7.5
$ type python2
python2 is /usr/bin/python2
$ type python3
bash: type: python3: not found
$ env python
Python 2.7.5 (default, Aug  7 2019, 00:51:29)
[GCC 4.8.5 20150623 (Red Hat 4.8.5-39)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
and if I activate the SCL for Python 3:
$ scl enable rh-python36 bash
[joel at localhost rtems-work]$ type python
python is /opt/rh/rh-python36/root/usr/bin/python
[joel at localhost rtems-work]$ python --version
Python 3.6.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191125/79206fdf/attachment.html>
