New Build System Status
    Chris Johns
    chrisj at rtems.org
    Tue Nov 26 01:11:29 UTC 2019
On 26/11/19 11:55 am, Joel Sherrill wrote:
> On Mon, Nov 25, 2019, 6:30 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 26/11/19 10:46 am, Joel Sherrill wrote:
>     > On Mon, Nov 25, 2019 at 5:28 PM Chris Johns <chrisj at rtems.org
>     > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
>     >     On 26/11/19 9:57 am, Joel Sherrill wrote:
>     >     > On Mon, Nov 25, 2019 at 3:19 PM Chris Johns <chrisj at rtems.org
>     >     > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>
>     <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>>> wrote:
>     >     >     On 26/11/19 8:05 am, Joel Sherrill wrote:
>     >     >     > On Mon, Nov 25, 2019 at 2:12 AM Sebastian Huber
>     >     >     > <sebastian.huber at embedded-brains.de
>     <mailto:sebastian.huber at embedded-brains.de>
>     <mailto:sebastian.huber at embedded-brains.de>>
>     >     >     <mailto:sebastian.huber at embedded-brains.de
>     <mailto:sebastian.huber at embedded-brains.de>>>
>     <mailto:sebastian.huber at embedded-brains.de>>>>>
>     >     >     > wrote:
>     >     >     >     On 25/11/2019 08:55, Chris Johns wrote:
>     >     >     >     > On 25/11/19 5:28 pm, Sebastian Huber wrote:
>     >     >     >     >> On 24/11/2019 23:25, Chris Johns wrote:
>     >     >     >     >>>>> Should there be a note or something about waf needing
>     >     python and we
>     >     >     >     recommend
>     >     >     >     >>>>> python3? Plus waf needs a `python` installed and not
>     just
>     >     >     `python2` or
>     >     >     >     >>>>> `python3`?
>     >     >     >     >>>> I think this belongs to the Host Computer section.
>     The quick
>     >     >     start uses the
>     >     >     >     >>>> RSB, so if you managed to build the tools, you must
>     have a
>     >     >     working Python.
>     >     >     >     >>>> The RSB uses Python and the RTEMS Tools use waf.
>     >     >     >     >>> The RSB can use python2 or python3 without a python. What
>     >     about a note
>     >     >     >     to say
>     >     >     >     >>> ... "Waf uses python and you need to make this command
>     available
>     >     >     on your
>     >     >     >     system".
>     >     >     >     >> Now I am a bit confused. I thought every UNIX-like system
>     >     provides a
>     >     >     >     >> #!/usr/bin/env python
>     >     >     >     >> which maps to Python 2 or 3?
>     >     >     >     > Apparently on some distros the python executable is not
>     >     automatically
>     >     >     >     installed
>     >     >     >     > with a suitable python2 or python3. I am not aware of the
>     >     specifics of
>     >     >     >     this but
>     >     >     >     > it was raised as an issue that I fixed in the RSB:
>     >     >     >     > https://devel.rtems.org/ticket/3537
>     >     >     >     I have never seen a system in which
>     >     >     >     #!/usr/bin/env python2
>     >     >     >     or
>     >     >     >     #!/usr/bin/env python3
>     >     >     >     works, but not
>     >     >     I agree however this is the post from Joel about a class he held ...
>     >     >     https://lists.rtems.org/pipermail/devel/2018-October/023150.html
>     >     >     and I posted the change here ...
>     >     >     https://lists.rtems.org/pipermail/devel/2018-October/023296.html
>     >     >     >     How many Python scripts would stop to work in this case?
>     >     However, the
>     >     >     >     availability of a python command is not mandatory
>     according to:
>     >     >     >     https://www.python.org/dev/peps/pep-0394/
>     >     >     I am aware of this and I support it however Linux distros seems to
>     >     feel there
>     >     >     are cases for exceptions, we have this one and there is also pax.
>     >     >     The pax and this python case are similar, do we say "We are correct,
>     >     fix your
>     >     >     host or raise a bug on your distro" or do we attempt to smooth over
>     >     the cracks
>     >     >     and attempt to just work?
>     >     >     In the case of ubuntu, maybe someone with some experience with
>     it can
>     >     see what
>     >     >     is needed and update the documentation?
>     >     >     >     I think we should note in the "Host Computer" section that a
>     >     "python"
>     >     >     >     command is mandatory for RTEMS and remove the RSB extra stuff.
>     >     >     The argument was presented to me that the RSB should just work
>     even in
>     >     this case
>     >     >     and so that is what I did. I am fine to remove that support, it
>     is an
>     >     >     average hack.
>     >     >     > Chris can answer to that.
>     >     >     Done.
>     >     >     > But on Centos 7, we have:
>     >     >     > $ type python
>     >     >     > python is /usr/bin/python
>     >     >     > $ python --version
>     >     >     > Python 2.7.5
>     >     >     > $ type python2
>     >     >     > python2 is /usr/bin/python2
>     >     >     > $ type python3
>     >     >     > bash: type: python3: not found
>     >     >     > $ env python
>     >     >     > Python 2.7.5 (default, Aug  7 2019, 00:51:29)
>     >     >     > [GCC 4.8.5 20150623 (Red Hat 4.8.5-39)] on linux2
>     >     >     > Type "help", "copyright", "credits" or "license" for more
>     information.
>     >     >     > and if I activate the SCL for Python 3:
>     >     >     > $ scl enable rh-python36 bash
>     >     >     > [joel at localhost rtems-work]$ type python
>     >     >     > python is /opt/rh/rh-python36/root/usr/bin/python
>     >     >     > [joel at localhost rtems-work]$ python --version
>     >     >     > Python 3.6.3
>     >     >     And on ubuntu? The original post was about that distro.
>     >     >  Welcome to Ubuntu 18.04.3 LTS (GNU/Linux 4.15.0-66-generic x86_64)
>     >     > $ type python
>     >     > Python 2.7.15+
>     >     > $ env python
>     >     > Python 2.7.15+ (default, Oct  7 2019, 17:39:04)
>     >     > [GCC 7.4.0] on linux2
>     >     > Type "help", "copyright", "credits" or "license" for more information.
>     >     > $ python2
>     >     > $ python3
>     >     > Python 3.6.8 (default, Oct  7 2019, 12:59:55)
>     >     > [GCC 8.3.0] on linux
>     >     I am sorry but I am not sure how this helps the discussion? Your
>     original post
>     >     last year raised the issue of no python being installed on ubuntu and
>     that lead
>     >     to the change in the RSB.
>     > I wish I had included the Ubuntu version in the original post. msys2 and
>     cygwin
>     > always seem to reflect the day you install them to me. The best I could do is
>     > report on the msys2 on my laptop and the Ubuntu we use for testing appear
>     to be OK.
>     > I have no way to reproduce what happened in the class I sent an email about.
>     > I assure you that it happened though.
>     I am sure it did happen. I reported at the time the python symlink is part of
>     the python-minimal package. I have no idea how this sits in that distro's
>     packaging structure and how it can happen.
>     What does you version show for ...
>      apt-file search /usr/bin/python | grep "/usr/bin/python$"
>     > On the master, I suppose assuming "python" exists is OK as an experiment
>     as long
>     > as it is assumed it may be Python2 or Python3. We should be prepared for
>     someone
>     > to have the situation where it doesn't work out though and need to revisit
>     this.
>     Are you saying it is OK to remove the support I added from the RSB and
>     rtems-tools?
> I am saying I have no system to prove it right now. I think it is still needed
> but can't reproduce it.
> I don't like removing it quietly without a replacement to detect and report
> something to a user that X occurred, please report so we know what hosts this
> happens on.
What happens with the new build system and waf as it now requires a valid
python? This is the point Sebastian is making and it is a valid one. We also
have rtems-tools and libbsd which already exist and have the same issue.
