New Build System Status
Chris Johns
chrisj at rtems.org
Tue Nov 26 23:59:58 UTC 2019
On 27/11/19 2:07 am, Sebastian Huber wrote:
> I updated the build system documentation.
Thank you.
> It is now sufficiently good to get integrated from my point of view.
Excellent and well done. However it cannot be merged until the question I raised
here is resolved ...
https://lists.rtems.org/pipermail/devel/2019-November/056225.html
Joel raised it and it is valid so I feel we should to wait until he responds. Joel?
> https://ftp.rtems.org/pub/rtems/people/sebh/eng.pdf
This is a really great start piece of work. To have this from the start is so good.
8.1 Should the install location be specified rather than referencing something
that is not specified?
"Configurable things which define what is built and how the artefacts are
configured are intended to be placed in configuration files."
to
" Configurable things which define what is built and how the artefacts are
configured are intended to be placed in configuration files that can be
configuration controlled."
"The wscript file should know nothing ..."
to
"The waf build script file called wscript should know nothing ..."
8.2
What is the link to "RTEMS User Manual"? I think inter-document links are
problematic. Referencing the docs.rtems.org can result in version mismatches.
Should there be a simple overview sequence picture ...
get defaults
+-- edit --+
configure
build
install
... as I think it would help explain the next sections?
8.3 Please add an example of the command. I know what you mean however I suspect
I am one of a few who would.
8.5
Order: In the trade off case how does someone get a current picture of this
structure so they can determine a suitable value?
cflags: Can any valid cflags be added here? Are there constraints on cflags and
any of the other types of flags listed? The example uses [], is this a valid
YAML syntax?
8.5.2 The cflags page reference is wrong, I see cflags on page 118 and not 116.
format: Does a valid python string mean suitable indenting? Does it need to meet
any required indent level or is in self contained?
name: Any constraints such as valid characters that can be used?
> https://ftp.rtems.org/pub/rtems/people/sebh/user.pdf
Nice work.
The last step does another `cd` to the RTEMS source, could this be confusing?
7.3 More external links. Same issue as the eng manual, I cannot see how these
can be made to work for any build of documentation at any location for the
various types of output we generate.
