New Build System Status
Sebastian Huber
Wed Nov 27 10:01:20 UTC 2019
On 27/11/2019 00:59, Chris Johns wrote:
> On 27/11/19 2:07 am, Sebastian Huber wrote:
>> I updated the build system documentation.
> Thank you.
Thanks for having a look at it and the very helpful comments.
>> It is now sufficiently good to get integrated from my point of view.
> Excellent and well done. However it cannot be merged until the question I raised
> here is resolved ...
> https://lists.rtems.org/pipermail/devel/2019-November/056225.html
> Joel raised it and it is valid so I feel we should to wait until he responds. Joel?
>> https://ftp.rtems.org/pub/rtems/people/sebh/eng.pdf
> This is a really great start piece of work. To have this from the start is so good.
> 8.1 Should the install location be specified rather than referencing something
> that is not specified?
> "Configurable things which define what is built and how the artefacts are
> configured are intended to be placed in configuration files."
> to
> " Configurable things which define what is built and how the artefacts are
> configured are intended to be placed in configuration files that can be
> configuration controlled."
> "The wscript file should know nothing ..."
> to
> "The waf build script file called wscript should know nothing ..."
Ok, I reworded this.
> 8.2
> What is the link to "RTEMS User Manual"? I think inter-document links are
> problematic. Referencing the docs.rtems.org can result in version mismatches.
I think links to other documents are quite helpful. We should find a way
to make them happen. For example a script could adjust the URLs in a
release branch from the "master" to the right version. Maybe add the
manuals to
common/rtemsdomain.py
and reference chapters/sections by name?
> Should there be a simple overview sequence picture ...
> get defaults
> +-- edit --+
> configure
> build
> install
> ... as I think it would help explain the next sections?
I think this is already covered by the User Manual content.
> 8.3 Please add an example of the command. I know what you mean however I suspect
> I am one of a few who would.
Ok, done.
> 8.5
> Order: In the trade off case how does someone get a current picture of this
> structure so they can determine a suitable value?
Ok, I restructured this section.
> cflags: Can any valid cflags be added here? Are there constraints on cflags and
> any of the other types of flags listed?
Currently, no variable substitution is performed on the flags. This is a
fine tuning option. We should measure how much performance the
substitution would cost.
> The example uses [], is this a valid
> YAML syntax?
Yes, of course. It denotes an empty list.
> 8.5.2 The cflags page reference is wrong, I see cflags on page 118 and not 116.
Hm, this looks like a Sphinx/Tex bug. The figure moves into the space
between the label and the content.
.. _BuildAttrCflags:
cflags
The `cflags` value shall be a list of options for the C compiler.
I don't know how to fix this.
> format: Does a valid python string mean suitable indenting? Does it need to meet
> any required indent level or is in self contained?
I added an example.
> name: Any constraints such as valid characters that can be used?
I added a regular expression.
>> https://ftp.rtems.org/pub/rtems/people/sebh/user.pdf
> Nice work.
> The last step does another `cd` to the RTEMS source, could this be confusing?
I think the boxes should be self-contained, e.g. if a command needs to
be called in a certain directory, then this should be ensured.
> 7.3 More external links. Same issue as the eng manual, I cannot see how these
> can be made to work for any build of documentation at any location for the
> various types of output we generate.
See above.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
