New Build System Status
Wed Nov 27 12:26:21 UTC 2019
On 27/11/2019 13:17, Hesham Almatary wrote:
> On Wed, 27 Nov 2019 at 11:59, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 27/11/2019 12:49, Hesham Almatary wrote:
>>> Hi Sebastian,
>>> Thanks for that great effort. I'd aim to use this build system for my
>>> RISC-V development.
>>> I followed the user manual trying to build RISC-V targets and RTEMS
>>> (aaf7f8b84) and here are a few comments:
>>> * .waf bsp_defaults doesn't give an error when mistyping the BSP name,
>>> but just outputs an empty .ini file.
>> If there is no matching BSP, then you get nothing. I think this is the
>> right thing to do. Doing a
>> ./waf bsp_defaults --rtems-bsps=riscv/rv64imac_medany  > bsps.ini
>> is not a recommended use case. You should only set the necessary minimum
>> of options.
> Not sure, I only wanted to build a specific BSP variant without having
> to build all variants. Is that not recommended?
This is fine, but I would not dump all options into the config.ini,
maybe just:
[riscv/rv64imac_medany]
COMPILER = clang
BUILD_TESTS = True
>>> * ./waf complains about not finding gcc if I don't give it the
>>> --prefix, even though it's in my PATH
>> Yes, this is currently the intentional behaviour. Should this be changed to
>> conf.find_program(XYZ, path_list=tools +
>> environ.get('PATH','').split(os.pathsep))
> I think that makes sense (also for default prefix?), but it would
> still be useful to be able to override that with --prefix to use
> different installed toolchains if needed.
Chris, what is your opinion on this?
>>> * dltests fail to build on RISC-V when BUILD_TESTS = True
>> Yes, this is work in progress. I should work now.
> Thanks.
>>> * Can't find  any "*.exe" after a default build:
>> Ok, this is a bug, you should find the samples.
> Is it reproducible?
I will have a look at this later.
>>> * Can't notice a difference when I pass rtems-compiler=clang, it still
>>> builds with gcc.
>> You have to set the compiler in the config.ini file, see latest user
>> documentation:
> Thanks it works fine when I add the flag to config.ini. Is
> rtems-compiler=clang useless this way?
This option is useful to get the default values depending on the
selected compiler, see example in:
>> https://ftp.rtems.org/pub/rtems/people/sebh/user.pdf
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
