New Build System Status
Hesham Almatary hesham.almatary at cl.cam.ac.uk
Wed Nov 27 13:10:33 UTC 2019
On Wed, 27 Nov 2019 at 12:53, Sebastian Huber
> On 27/11/2019 13:26, Sebastian Huber wrote:
> >>>> * Can't find  any "*.exe" after a default build:
> >>> Ok, this is a bug, you should find the samples.
> >> Is it reproducible?
> > I will have a look at this later.
> Sorry for the confusion. This is intentional, by default no tests are
> built. Should I change the default to build the samples?
No worries. I set BUILD_SAMPLES=True and it builds fine. I have no
particular opinion on the default behaviour, but if it's a requirement
that the defaults for the new build system meet the autoconf's
defaults, then maybe yes.
> devel mailing list
> devel at rtems.org
