New Build System Status
Wed Nov 27 13:53:02 UTC 2019
On 27/11/2019 14:42, Joel Sherrill wrote:
> On Wed, Nov 27, 2019 at 7:11 AM Hesham Almatary
> <hesham.almatary at cl.cam.ac.uk <mailto:hesham.almatary at cl.cam.ac.uk>> wrote:
>     On Wed, 27 Nov 2019 at 12:53, Sebastian Huber
>     <sebastian.huber at embedded-brains.de
>     <mailto:sebastian.huber at embedded-brains.de>> wrote:
>      > On 27/11/2019 13:26, Sebastian Huber wrote:
>      > >>>> * Can't find  any "*.exe" after a default build:
>      > >>> Ok, this is a bug, you should find the samples.
>      > >> Is it reproducible?
>      > > I will have a look at this later.
>      > Sorry for the confusion. This is intentional, by default no tests are
>      > built. Should I change the default to build the samples?
>     No worries. I set BUILD_SAMPLES=True and it builds fine. I have no
>     particular opinion on the default behaviour, but if it's a requirement
>     that the defaults for the new build system meet the autoconf's
>     defaults, then maybe yes.
> I think it would be better to start with the same defaults as the autoconf
> build system.
Ok, I changed it.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
