[PATCH] bsp/erc32: Improve pseudo-SMP support
Tue Oct 1 06:58:17 UTC 2019
Add support for _SMP_Send_message() to the own processor.  This is
required by the smpmulticast01 test program.
 bsps/sparc/erc32/start/bspsmp.c          | 84 ++++++++++++++++++++++++++++++++
 c/src/lib/libbsp/sparc/erc32/Makefile.am |  3 +-
 2 files changed, 85 insertions(+), 2 deletions(-)
 create mode 100644 bsps/sparc/erc32/start/bspsmp.c
diff --git a/bsps/sparc/erc32/start/bspsmp.c b/bsps/sparc/erc32/start/bspsmp.c
new file mode 100644
index 0000000000..35ed2bd0d0
--- /dev/null
+++ b/bsps/sparc/erc32/start/bspsmp.c
@@ -0,0 +1,84 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 embedded brains GmbH
+ * are met:
+#include <rtems/score/smpimpl.h>
+#include <rtems/score/assert.h>
+#include <rtems/sysinit.h>
+#include <bsp.h>
+#define IPI_VECTOR SPARC_SYNCHRONOUS_TRAP( 0x90 )
+uint32_t _CPU_SMP_Get_current_processor( void )
+  return 0;
+uint32_t _CPU_SMP_Initialize( void )
+  return 1;
+bool _CPU_SMP_Start_processor( uint32_t cpu_index )
+  (void) cpu_index;
+  return true;
+void _CPU_SMP_Finalize_initialization( uint32_t cpu_count )
+  _Assert( cpu_count == 1 );
+  (void) cpu_count;
+void _CPU_SMP_Prepare_start_multitasking( void )
+void _CPU_SMP_Send_interrupt( uint32_t target_processor_index )
+  _Assert( target_processor_index == 0 );
+  (void) target_processor_index;
+  __asm__ volatile( "ta 0x10; nop " );
+static rtems_isr bsp_inter_processor_interrupt(
+  rtems_vector_number vector
+  _SMP_Inter_processor_interrupt_handler( _Per_CPU_Get() );
+static void erc32_install_inter_processor_interrupt( void )
+  set_vector( bsp_inter_processor_interrupt, IPI_VECTOR, 1 );
+RTEMS_SYSINIT_ITEM(
+  erc32_install_inter_processor_interrupt,
+  RTEMS_SYSINIT_BSP_PRE_DRIVERS,
+  RTEMS_SYSINIT_ORDER_LAST
diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
index 994e55cc40..8cdd4581bf 100644
--- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
+++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
@@ -55,8 +55,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc/shared/irq/bsp_isr_handler
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
 if HAS_SMP
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspsmp-dummy.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/getcurrentprocessor-zero.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc/erc32/start/bspsmp.c
 endif
 if HAS_NETWORKING
2.16.4
