[PATCH] dosfs: Fix format with media block sizes > 512
Sebastian Huber
Tue Oct 1 08:02:01 UTC 2019
cpukit/libfs/src/dosfs/msdos_format.c | 93 +++++++++++++++++------------------
1 file changed, 46 insertions(+), 47 deletions(-)
diff --git a/cpukit/libfs/src/dosfs/msdos_format.c b/cpukit/libfs/src/dosfs/msdos_format.c
index 42f1d74575..326040f004 100644
--- a/cpukit/libfs/src/dosfs/msdos_format.c
+++ b/cpukit/libfs/src/dosfs/msdos_format.c
@@ -65,6 +65,7 @@ typedef struct {
bool VolLabel_present;
uint32_t vol_id;
bool skip_alignment;
+ char *sec;
} msdos_format_param_t;
@@ -180,11 +181,11 @@ static int msdos_format_fill_sectors
| Input Parameters: |
+ msdos_format_param_t *fmt_params,
const msdos_format_request_param_t *rqdata,
int fd, /* file descriptor index */
uint32_t start_sector, /* sector number to fill to */
uint32_t sector_cnt, /* number of sectors to fill to */
- uint32_t sector_size, /* size of sector */
const char fill_byte /* byte to fill into sectors */
@@ -193,22 +194,14 @@ static int msdos_format_fill_sectors
int ret_val = 0;
- char *fill_buffer = NULL;
uint32_t total_sectors = sector_cnt;
int last_percent = -1;
- * allocate and fill buffer
+ * fill buffer
if (ret_val == 0) {
- fill_buffer = malloc(sector_size);
- if (fill_buffer == NULL) {
- errno = ENOMEM;
- ret_val = -1;
- else {
- memset(fill_buffer,fill_byte,sector_size);
+ memset(fmt_params->sec,fill_byte,fmt_params->bytes_per_sector);
msdos_format_printf (rqdata, MSDOS_FMT_INFO_LEVEL_DETAIL,
@@ -224,7 +217,9 @@ static int msdos_format_fill_sectors
msdos_format_printf (rqdata, MSDOS_FMT_INFO_LEVEL_DETAIL, ".");
last_percent = percent;
- ret_val = msdos_format_write_sec(fd,start_sector,sector_size,fill_buffer);
+ ret_val = msdos_format_write_sec(fd,start_sector,
+ fmt_params->bytes_per_sector,
+ fmt_params->sec);
start_sector++;
sector_cnt--;
@@ -235,13 +230,6 @@ static int msdos_format_fill_sectors
msdos_format_printf (rqdata, MSDOS_FMT_INFO_LEVEL_INFO,
"filling error on sector: %d\n", start_sector);
- * cleanup
- if (fill_buffer != NULL) {
- free(fill_buffer);
- fill_buffer = NULL;
return ret_val;
@@ -1016,13 +1004,14 @@ int msdos_format
| 0, if success, -1 and errno if failed |
- char tmp_sec[FAT_TOTAL_MBR_SIZE];
struct stat stat_buf;
int ret_val = 0;
int fd = -1;
int i;
msdos_format_param_t fmt_params;
+ memset(&fmt_params, 0, sizeof(fmt_params));
* open device for writing
@@ -1055,6 +1044,14 @@ int msdos_format
if (ret_val == 0) {
ret_val = msdos_format_determine_fmt_params(fd,rqdata,&fmt_params);
+ if (ret_val == 0) {
+ fmt_params.sec = malloc(fmt_params.bytes_per_sector);
+ if (fmt_params.sec == NULL) {
+ ret_val = -1;
* if requested, write whole disk/partition with 0xe5
@@ -1062,11 +1059,11 @@ int msdos_format
(rqdata != NULL) &&
!(rqdata->quick_format)) {
ret_val = msdos_format_fill_sectors
- (rqdata,
+ (&fmt_params,
+ rqdata,
fd,
0, /* start sector */
fmt_params.totl_sector_cnt, /* sector count */
- fmt_params.bytes_per_sector,
0xe5);
@@ -1082,11 +1079,11 @@ int msdos_format
ret_val = msdos_format_read_sec(fd,
0,
- tmp_sec);
+ fmt_params.sec);
if (ret_val == 0) {
"generate MRB sector\n");
- ret_val = msdos_format_gen_mbr(tmp_sec,&fmt_params);
+ ret_val = msdos_format_gen_mbr(fmt_params.sec,&fmt_params);
@@ -1099,7 +1096,7 @@ int msdos_format
0,
- tmp_sec);
+ fmt_params.sec);
if ((ret_val == 0) &&
(fmt_params.mbr_copy_sec != 0)) {
@@ -1111,7 +1108,7 @@ int msdos_format
fmt_params.mbr_copy_sec ,
- tmp_sec);
+ fmt_params.sec);
@@ -1119,7 +1116,7 @@ int msdos_format
(fmt_params.fsinfo_sec != 0)) {
- ret_val = msdos_format_gen_fsinfo(tmp_sec);
+ ret_val = msdos_format_gen_fsinfo(fmt_params.sec);
* write fsinfo sector
@@ -1129,7 +1126,7 @@ int msdos_format
fmt_params.fsinfo_sec,
- tmp_sec);
+ fmt_params.sec);
* write FAT as all empty
@@ -1137,11 +1134,11 @@ int msdos_format
if (ret_val == 0) {
- (rqdata,
+ (&fmt_params,
+ rqdata,
fd,
fmt_params.rsvd_sector_cnt, /* start sector */
fmt_params.fat_num*fmt_params.sectors_per_fat,/* sector count */
0x00);
@@ -1150,25 +1147,25 @@ int msdos_format
if (ret_val == 0) {
- (rqdata,
+ (&fmt_params,
+ rqdata,
fd,
fmt_params.root_dir_start_sec, /* start sector */
fmt_params.root_dir_fmt_sec_cnt, /* sector count */
0x00);
* write volume label to first entry of directory
if ((ret_val == 0) && fmt_params.VolLabel_present) {
- memset(tmp_sec,0,sizeof(tmp_sec));
- memcpy(MSDOS_DIR_NAME(tmp_sec),fmt_params.VolLabel,MSDOS_SHORT_NAME_LEN);
- *MSDOS_DIR_ATTR(tmp_sec) = MSDOS_ATTR_VOLUME_ID;
+ memset(fmt_params.sec,0,fmt_params.bytes_per_sector);
+ memcpy(MSDOS_DIR_NAME(fmt_params.sec),fmt_params.VolLabel,MSDOS_SHORT_NAME_LEN);
+ *MSDOS_DIR_ATTR(fmt_params.sec) = MSDOS_ATTR_VOLUME_ID;
(fd,
- tmp_sec);
+ fmt_params.sec);
* write FAT entry 0 as (0xffffff00|Media_type)EOC,
@@ -1181,31 +1178,31 @@ int msdos_format
* empty sector: all clusters are free/do not link further on
switch(fmt_params.fattype) {
case FAT_FAT12:
/* LSBits of FAT entry 0: media_type */
- FAT_SET_VAL8(tmp_sec,0,(fmt_params.media_code));
+ FAT_SET_VAL8(fmt_params.sec,0,(fmt_params.media_code));
/* MSBits of FAT entry 0:0xf, LSBits of FAT entry 1: LSB of EOC */
- FAT_SET_VAL8(tmp_sec,1,(0x0f | (FAT_FAT12_EOC << 4)));
+ FAT_SET_VAL8(fmt_params.sec,1,(0x0f | (FAT_FAT12_EOC << 4)));
/* MSBits of FAT entry 1: MSBits of EOC */
- FAT_SET_VAL8(tmp_sec,2,(FAT_FAT12_EOC >> 4));
+ FAT_SET_VAL8(fmt_params.sec,2,(FAT_FAT12_EOC >> 4));
break;
case FAT_FAT16:
/* FAT entry 0: 0xff00|media_type */
- FAT_SET_VAL8(tmp_sec,0,fmt_params.media_code);
- FAT_SET_VAL8(tmp_sec,1,0xff);
+ FAT_SET_VAL8(fmt_params.sec,0,fmt_params.media_code);
+ FAT_SET_VAL8(fmt_params.sec,1,0xff);
/* FAT entry 1: EOC */
- FAT_SET_VAL16(tmp_sec,2,FAT_FAT16_EOC);
+ FAT_SET_VAL16(fmt_params.sec,2,FAT_FAT16_EOC);
break;
case FAT_FAT32:
/* FAT entry 0: 0xffffff00|media_type */
- FAT_SET_VAL32(tmp_sec,0,0xffffff00|fmt_params.media_code);
+ FAT_SET_VAL32(fmt_params.sec,0,0xffffff00|fmt_params.media_code);
/* FAT entry 1: Not dirty, no IO error, EOC */
- FAT_SET_VAL32(tmp_sec,4,0xc0000000|FAT_FAT32_EOC);
+ FAT_SET_VAL32(fmt_params.sec,4,0xc0000000|FAT_FAT32_EOC);
break;
default:
@@ -1218,7 +1215,7 @@ int msdos_format
* to root directory, and is end of chain
* mark this in every copy of the FAT
- FAT_SET_VAL32(tmp_sec,8,FAT_FAT32_EOC);
+ FAT_SET_VAL32(fmt_params.sec,8,FAT_FAT32_EOC);
start_sector = loc_align_object (fmt_params.rsvd_sector_cnt,
@@ -1232,7 +1229,7 @@ int msdos_format
start_sector
+ (i * fmt_params.sectors_per_fat),
- tmp_sec);
+ fmt_params.sec);
@@ -1249,5 +1246,7 @@ int msdos_format
close(fd);
+ free(fmt_params.sec);
return ret_val;
2.16.4
