How to build start.o using waf?
Gedare Bloom
gedare at rtems.org
Wed Oct 2 17:30:51 UTC 2019
On Wed, Oct 2, 2019 at 5:12 AM Sebastian Huber
> On 30/09/2019 15:14, Sebastian Huber wrote:
> > Hello,
> > I would like to work on a new build system prototype. The idea is to use
> > specification items maintained by Doorstop (YAML files), a Python
> > configuration script and waf to build RTEMS and the tests. This is
> > similar to the libbsd build. The difference is that in libbsd the build
> > data is maintained directly in Python code (libbsd.py).
> > How do you build a singe object file (start.o) from assembly files in
> > waf? An example would be great.
> I think I found it in:
> https://git.rtems.org/amar/waf-old.git/tree/py/waf/builder.py#n54
> def start(self, source, defines=[]):
> from os.path import splitext, basename
> for s in source:
> file = splitext(basename(s))[0]
> self.ctx(
> rule = '${CC} -DASM ${CFLAGS} ${CPPFLAGS} ${DEFINES_ST:DEFINES}
> ${CPPPATH_ST:INCPATHS} -c -o ${TGT} ${SRC}',
> source = s,
> target = "%s.o" % file,
> name = "start_%s_o" % file,
> features = "c casm bld_include src_include",
> defines = defines,
It seems likely for a simple link you'd only need features="casm",
although I'm not sure.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
