How to build start.o using waf?
Sebastian Huber
Wed Oct 2 11:12:46 UTC 2019
On 30/09/2019 15:14, Sebastian Huber wrote:
> Hello,
> I would like to work on a new build system prototype. The idea is to use
> specification items maintained by Doorstop (YAML files), a Python
> configuration script and waf to build RTEMS and the tests. This is
> similar to the libbsd build. The difference is that in libbsd the build
> data is maintained directly in Python code (libbsd.py).
> How do you build a singe object file (start.o) from assembly files in
> waf? An example would be great.
I think I found it in:
https://git.rtems.org/amar/waf-old.git/tree/py/waf/builder.py#n54
def start(self, source, defines=[]):
from os.path import splitext, basename
for s in source:
file = splitext(basename(s))[0]
self.ctx(
rule = '${CC} -DASM ${CFLAGS} ${CPPFLAGS} ${DEFINES_ST:DEFINES}
${CPPPATH_ST:INCPATHS} -c -o ${TGT} ${SRC}',
source = s,
target = "%s.o" % file,
name = "start_%s_o" % file,
features = "c casm bld_include src_include",
defines = defines,
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
