[PATCH 1/3] rtems/confdefs.h add another initial extension set
Thu Oct 3 22:08:11 UTC 2019
This adds back the capability for the BSP to configure an
initial extension that is specific to itself. The parameter
BSP_INITIAL_EXTENSION was taken over by having a standard
fatal extension installed using the same name.
 cpukit/include/rtems/confdefs.h | 3 +++
 1 file changed, 3 insertions(+)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 5eb5425..e1a255a 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -2136,6 +2136,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #if defined(CONFIGURE_INITIAL_EXTENSIONS)
       CONFIGURE_INITIAL_EXTENSIONS,
     #endif
+    #if defined(BSP_INITIAL2_EXTENSIONS)
+      BSP_INITIAL2_EXTENSIONS,
+    #endif
     #if defined(BSP_INITIAL_EXTENSION)
     #endif
1.8.3.1
