[PATCH 1/3] rtems/confdefs.h add another initial extension set
Sebastian Huber
Fri Oct 4 05:02:08 UTC 2019
On 04/10/2019 00:08, Joel Sherrill wrote:
> This adds back the capability for the BSP to configure an
> initial extension that is specific to itself. The parameter
> BSP_INITIAL_EXTENSION was taken over by having a standard
> fatal extension installed using the same name.
> cpukit/include/rtems/confdefs.h | 3 +++
> 1 file changed, 3 insertions(+)
> diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
> index 5eb5425..e1a255a 100644
> --- a/cpukit/include/rtems/confdefs.h
> +++ b/cpukit/include/rtems/confdefs.h
> @@ -2136,6 +2136,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
> #if defined(CONFIGURE_INITIAL_EXTENSIONS)
> CONFIGURE_INITIAL_EXTENSIONS,
> #endif
> + #if defined(BSP_INITIAL2_EXTENSIONS)
> + BSP_INITIAL2_EXTENSIONS,
> + #endif
> #if defined(BSP_INITIAL_EXTENSION)
> #endif
I don't think this patch is necessary. A BSP is free to provide its own
initial extension. Just don't add the
#include <bsp/default-initial-extension.h>
to the bsp.h.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
