Testing the interrupt extension API?
Fri Oct 4 06:35:52 UTC 2019
On 03/10/2019 07:44, Chris Johns wrote:
> On 2/10/19 5:28 pm, Sebastian Huber wrote:
>> the interrupt extension API implementation is already quite complex and not
>> covered by the test suite:
>> https://git.rtems.org/rtems/tree/bsps/shared/irq
>> In order to write generic tests for this we have to know which interrupt vector
>> can be controlled by software.
> Do I assume the testsuite's tests are for hard IP resources?
The test would only use interrupts which are not connected to a peripheral.
> One approach would be to add an
>> rtems_interrupt_get_capabilities() function:
> It would be nice to be able to add and remove entries based on soft IP that can
> be runtime loaded. :)
Every BSP needs to implement this function on their own.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
