Use YAML configuration files for the build?
Fri Oct 4 14:15:07 UTC 2019
On Fri, Oct 4, 2019 at 8:29 AM Sebastian Huber <
> Hello,
> I would like to use YAML configuration files for the new build system.
For what purpose? To achieve what end?
> The reason for this is that Doorstop uses this file format and I would
> like to maintain the build specification with Doorstop. The problem is
> that that a YAML encoder/decoder is not included in the standard Python
> library. So, everyone building RTEMS would be required to install the
> PyYAML package. On a Linux distribution this should be easily available.
> It can be also installed via "pip install pyyaml".
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191004/7b348f32/attachment.html>
