Use YAML configuration files for the build?
Joel Sherrill
joel at rtems.org
Fri Oct 4 17:41:26 UTC 2019
On Fri, Oct 4, 2019 at 12:25 PM Sebastian Huber <
> ----- Am 4. Okt 2019 um 16:15 schrieb joel joel at rtems.org:
> > On Fri, Oct 4, 2019 at 8:29 AM Sebastian Huber <
> >> Hello,
> >> I would like to use YAML configuration files for the new build system.
> > For what purpose?
> To store the items which define what and how the build is done, e.g. BSPs,
> BSP options, libraries, file groups for libraries, test programs.
pkgconfig type information?
Would this all be generated or a manually prepared input?
> > To achieve what end?
> Make it possible to re-use the build specification, e.g. generate
> documentation of the BSP options for the user manual.
Sounds like pkgconfig in Yaml format.
Is it different?
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191004/e81aeb41/attachment.html>
