[PATCH 1/3] rtems/confdefs.h add another initial extension set
Sebastian Huber
Mon Oct 7 08:22:37 UTC 2019
On 04/10/2019 16:05, Joel Sherrill wrote:
> On Fri, Oct 4, 2019 at 12:02 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 04/10/2019 00:08, Joel Sherrill wrote:
> > This adds back the capability for the BSP to configure an
> > initial extension that is specific to itself. The parameter
> > BSP_INITIAL_EXTENSION was taken over by having a standard
> > fatal extension installed using the same name.
> > cpukit/include/rtems/confdefs.h | 3 +++
> > 1 file changed, 3 insertions(+)
> > diff --git a/cpukit/include/rtems/confdefs.h
> b/cpukit/include/rtems/confdefs.h
> > index 5eb5425..e1a255a 100644
> > --- a/cpukit/include/rtems/confdefs.h
> > +++ b/cpukit/include/rtems/confdefs.h
> > @@ -2136,6 +2136,9 @@ extern rtems_initialization_tasks_table
> Initialization_tasks[];
> > #if defined(CONFIGURE_INITIAL_EXTENSIONS)
> > CONFIGURE_INITIAL_EXTENSIONS,
> > #endif
> > + #if defined(BSP_INITIAL2_EXTENSIONS)
> > + BSP_INITIAL2_EXTENSIONS,
> > + #endif
> > #if defined(BSP_INITIAL_EXTENSION)
> > #endif
> I don't think this patch is necessary. A BSP is free to provide its own
> initial extension. Just don't add the
> #include <bsp/default-initial-extension.h>
> to the bsp.h.
> And why would I want to lose the default fatal extension? The point of
> was for a BSP to add it's own extensions. I like the default extensions
> but the BSP should still have a
> hook.
> I would prefer to rename this to BSP_FATAL_EXTENSION and leave the
> available.
> I think I could fix this by for this BSP by something like this:
> #undef BSP_INITIAL_EXTENSION
> #define BSP_INITIAL_EXTENSION
> ... switch extension ...,
> ... default fatal extension
> Is that what you are proposing a user should do if they want to another
> extension but still
> use the default fatal extension?
> FWIW other BSPs uses this default extension and just provide their
> own bsp_fatal_extension()
> implementation. That seems OK and slightly different from my use case.
I think a BSP should just provide one extension via
BSP_INITIAL_EXTENSION defined by <bsp.h>. The declaration of
bsp_fatal_extension() should move to a separate header file. It can then
be used in a custom BSP extension.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
