[PATCH 1/3] rtems/confdefs.h add another initial extension set
Fri Oct 4 14:05:12 UTC 2019
On Fri, Oct 4, 2019 at 12:02 AM Sebastian Huber <
> On 04/10/2019 00:08, Joel Sherrill wrote:
> > This adds back the capability for the BSP to configure an
> > initial extension that is specific to itself. The parameter
> > BSP_INITIAL_EXTENSION was taken over by having a standard
> > fatal extension installed using the same name.
> >   cpukit/include/rtems/confdefs.h | 3 +++
> >   1 file changed, 3 insertions(+)
> > diff --git a/cpukit/include/rtems/confdefs.h
> b/cpukit/include/rtems/confdefs.h
> > index 5eb5425..e1a255a 100644
> > --- a/cpukit/include/rtems/confdefs.h
> > +++ b/cpukit/include/rtems/confdefs.h
> > @@ -2136,6 +2136,9 @@ extern rtems_initialization_tasks_table
> Initialization_tasks[];
> >       #if defined(CONFIGURE_INITIAL_EXTENSIONS)
> >         CONFIGURE_INITIAL_EXTENSIONS,
> >       #endif
> > +    #if defined(BSP_INITIAL2_EXTENSIONS)
> > +      BSP_INITIAL2_EXTENSIONS,
> > +    #endif
> >       #if defined(BSP_INITIAL_EXTENSION)
> >       #endif
> I don't think this patch is necessary. A BSP is free to provide its own
> initial extension. Just don't add the
> #include <bsp/default-initial-extension.h>
> to the bsp.h.
And why would I want to lose the default fatal extension? The point of
was for a BSP to add it's own extensions. I like the default extensions but
the BSP should still have a
hook.
I would prefer to rename this to BSP_FATAL_EXTENSION and leave the
available.
I think I could fix this by for this BSP by something like this:
#undef BSP_INITIAL_EXTENSION
#define BSP_INITIAL_EXTENSION
     ... switch extension ...,
    ... default fatal extension
Is that what you are proposing a user should do if they want to another
extension but still
use the default fatal extension?
FWIW other BSPs uses this default extension and just provide their
own bsp_fatal_extension()
implementation. That seems OK and slightly different from my use case.
When BSP_INITIAL_EXTENSION was re-purposed for the default extension, it
took it away as
an unused configuration point available to a BSP developer.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191004/e51c1a9d/attachment.html>
