rtems-bsp-builder failure
Joel Sherrill
joel at rtems.org
Thu Oct 10 13:15:34 UTC 2019
Hi
Looks like the rtems-bsp-builder has a regression of some sort.
+ nohup time ./rtems-tools/tester/rtems-bsp-builder
--rtems=/home/joel/rtems-work/rtems --build-path=build
--prefix=/home/joel/rtems-work/bsps --log=build.log
--warnings-report=warnings.log --mail --mail-from=joel at rtems.org --mail-to=
build at rtems.org --profiles=everything --jobs=6/12
[joel at rtbf64c rtems-work]$ tail -f nohup.out
BSP Build FAILED
RTEMS Tools Project - RTEMS Kernel BSP Builder, 5 (30a5cd65cc54)
Mail: from:joel at rtems.org to:build at rtems.org smtp:localhost
Profile(s): everything
Cleaning: build
error: invalid BSP: ${arm:bsps}
Passes: 0 Failures: 0
0.26user 0.14system 0:01.25elapsed 32%CPU (0avgtext+0avgdata
14712maxresident)k
10080inputs+16outputs (75major+18998minor)pagefaults 0swaps
The command is from a script I have used for all my previous runs.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191010/55832265/attachment.html>
