rtems-bsp-builder failure
Fri Oct 11 01:30:33 UTC 2019
> On 11 Oct 2019, at 12:15 am, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> Looks like the rtems-bsp-builder has a regression of some sort.
> + nohup time ./rtems-tools/tester/rtems-bsp-builder --rtems=/home/joel/rtems-work/rtems --build-path=build --prefix=/home/joel/rtems-work/bsps --log=build.log --warnings-report=warnings.log --mail --mail-from=joel at rtems.org --mail-to=build at rtems.org --profiles=everything --jobs=6/12
> [joel at rtbf64c rtems-work]$ tail -f nohup.out
> BSP Build FAILED
> RTEMS Tools Project - RTEMS Kernel BSP Builder, 5 (30a5cd65cc54)
> Mail: from:joel at rtems.org to:build at rtems.org smtp:localhost
> Profile(s): everything
> Cleaning: build
> error: invalid BSP: ${arm:bsps}
> Passes: 0   Failures: 0
> 0.26user 0.14system 0:01.25elapsed 32%CPU (0avgtext+0avgdata 14712maxresident)k
> 10080inputs+16outputs (75major+18998minor)pagefaults 0swaps
> The command is from a script I have used for all my previous runs.
I suggest looking in the log file to see what has gone wrong.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191011/9f6778d7/attachment.html>
