[PATCH v4] riscv: add freedom E310 Arty A7 bsp
Pragnesh Patel pragnesh.patel at sifive.com
Fri Oct 11 06:18:52 UTC 2019
On Thu, Oct 10, 2019 at 8:50 PM Hesham Almatary
<hesham.almatary at cl.cam.ac.uk> wrote:
> On Wed, 9 Oct 2019 at 12:54, Pragnesh Patel <pragnesh.patel at sifive.com> wrote:
> > Added support for Sifive Freedom FE310 soc on Arty A7 FPGA board.
> > Update #3785.
> > Signed-off-by: Pragnesh Patel <pragnesh.patel at sifive.com>
> > Changes in v4:
> >   - Revert fdt32_t *val to const in riscv_clock_get_timebase_frequency()
> >   - make RISCV_ENABLE_FRDME310ARTY_SUPPORT consistent all over the code
> >   - Revert to the default configuration for riscv/configure.ac
> >   - Added riscv/config/frdme310arty.cfg as a new riscv config
> > Changes in v3:
> >   - Remove bsps/riscv/frdme310arty/ directory and added support for
> >     Freedom FE310 soc in common bsps/riscv/riscv/ directory
> >   - Added #define RISCV_ENABLE_FRDME310ARTY_SUPPORT in configure.ac
> >     to enable support for FE310
> >   - Change the RISCV_RAM_REGION_SIZE to 256 MB for riscv
> > Changes in v2:
> >   bsps/riscv/frdme310arty/btimer/btimer.c
> >     - Remove the read_csr() function from btimer.c
> >     - Remove CONFIG_BTIMER_RISCV_GET_MCYCLES macro to get time in
> >       microseconds
> >   bsps/riscv/frdme310arty/clock/clockdrv.c
> >   bsps/riscv/riscv/clock/clockdrv.c
> >     - Delete both files and Add bsps/riscv/shared/clock/clockdrv.c
> >     - riscv_clock_get_timebase_frequency(): Get timebase-frequency from
> >       cpus or cpu at 0 devicetree node because riscv uses "cpus" node and
> >       frdme310arty uses "cpu at 0" node to look for timebase-frequency
> >     - Remove rtems_counter_initialize_converter() and
> >       rtems_timecounter_simple_install() functions
> >   bsps/riscv/frdme310arty/include/bsp/riscv.h
> >     - Remove unused frdme310arty_l2c_base;
> >   bsps/riscv/frdme310arty/start/bsp_fatal_halt.c
> >   bsps/riscv/riscv/start/bsp_fatal_halt.c
> >     - Delete this file and Add bsps/riscv/shared/start/bsp_fatal_halt.c
> >   bsps/riscv/frdme310arty/start/bspstart.c
> >     - Remove unused function riscv_get_node_byname()
> >   bsps/riscv/frdme310arty/start/linkcmds.in
> >     - Use @RISCV_RAM_REGION_BEGIN@ and @RISCV_RAM_REGION_SIZE@ instead of
> >       hard coded values
> >   c/src/lib/libbsp/riscv/frdme310arty/Makefile.am
> >     - librtemsbsp_a_SOURCES -> bsps/riscv/shared/start/bsp_fatal_halt.c
> >     - librtemsbsp_a_SOURCES -> bsps/riscv/shared/clock/clockdrv.c
> >   c/src/lib/libbsp/riscv/frdme310arty/configure.ac
> >     - change RISCV_RAM_REGION_SIZE to default 256MiB
> >   bsps/riscv/riscv/irq/irq.c
> >     - Delete this irq.c and it will now use bsps/riscv/shared/irq/irq.c
> >   c/src/lib/libbsp/riscv/riscv/Makefile.am
> >     - librtemsbsp_a_SOURCES -> bsps/riscv/shared/irq/irq.c
> >  bsps/include/bsp/fatal.h                  |   3 +-
> >  bsps/riscv/riscv/clock/clockdrv.c         |  16 ++-
> >  bsps/riscv/riscv/config/frdme310arty.cfg  |   9 ++
> >  bsps/riscv/riscv/console/console-config.c |  57 ++++++++++
> >  bsps/riscv/riscv/console/fe310-uart.c     | 100 +++++++++++++++++
> >  bsps/riscv/riscv/dts/frdme310arty.dts     | 130 ++++++++++++++++++++++
> >  bsps/riscv/riscv/include/bsp/fe310-uart.h |  42 +++++++
> >  bsps/riscv/riscv/include/bsp/riscv.h      |   4 +
> >  bsps/riscv/riscv/start/bspstart.c         |  52 +++++++++
> >  c/src/lib/libbsp/riscv/riscv/Makefile.am  |   8 ++
> >  c/src/lib/libbsp/riscv/riscv/configure.ac |  16 ++-
> >  11 files changed, 430 insertions(+), 7 deletions(-)
> >  create mode 100644 bsps/riscv/riscv/config/frdme310arty.cfg
> >  create mode 100644 bsps/riscv/riscv/console/fe310-uart.c
> >  create mode 100644 bsps/riscv/riscv/dts/frdme310arty.dts
> >  create mode 100644 bsps/riscv/riscv/include/bsp/fe310-uart.h
> > diff --git a/bsps/include/bsp/fatal.h b/bsps/include/bsp/fatal.h
> > index fae5461699..3f8e1eb591 100644
> > --- a/bsps/include/bsp/fatal.h
> > +++ b/bsps/include/bsp/fatal.h
> > @@ -152,7 +152,8 @@ typedef enum {
> >    RISCV_FATAL_INVALID_PLIC_NDEV_IN_DEVICE_TREE,
> >    RISCV_FATAL_TOO_LARGE_PLIC_NDEV_IN_DEVICE_TREE,
> >    RISCV_FATAL_INVALID_INTERRUPT_AFFINITY,
> > -  RISCV_FATAL_NO_NS16550_INTERRUPTS_IN_DEVICE_TREE
> > +  RISCV_FATAL_NO_NS16550_INTERRUPTS_IN_DEVICE_TREE,
> > +  RISCV_FATAL_NO_TLCLOCK_FREQUENCY_IN_DEVICE_TREE
> >  } bsp_fatal_code;
> >  RTEMS_NO_RETURN static inline void
> > diff --git a/bsps/riscv/riscv/clock/clockdrv.c b/bsps/riscv/riscv/clock/clockdrv.c
> > index 7e6034d4d1..d085b6bd95 100644
> > --- a/bsps/riscv/riscv/clock/clockdrv.c
> > +++ b/bsps/riscv/riscv/clock/clockdrv.c
> > @@ -130,15 +130,21 @@ static uint32_t riscv_clock_get_timecount(struct timecounter *base)
> >  static uint32_t riscv_clock_get_timebase_frequency(const void *fdt)
> >    int node;
> > -  const uint32_t *val;
> > -  int len;
> > +  const fdt32_t *val;
> > +  int len=0;
> >    node = fdt_path_offset(fdt, "/cpus");
> > -  val = fdt_getprop(fdt, node, "timebase-frequency", &len);
> > +  val = (fdt32_t *) fdt_getprop(fdt, node, "timebase-frequency", &len);
> >    if (val == NULL || len < 4) {
> > -    bsp_fatal(RISCV_FATAL_NO_TIMEBASE_FREQUENCY_IN_DEVICE_TREE);
> > +    int cpu0 = fdt_subnode_offset(fdt, node, "cpu at 0");
> > +    val = (fdt32_t *) fdt_getprop(fdt, cpu0, "timebase-frequency", &len);
> > +    if (val == NULL || len < 4) {
> > +      bsp_fatal(RISCV_FATAL_NO_TIMEBASE_FREQUENCY_IN_DEVICE_TREE);
> >    return fdt32_to_cpu(*val);
> > diff --git a/bsps/riscv/riscv/config/frdme310arty.cfg b/bsps/riscv/riscv/config/frdme310arty.cfg
> > new file mode 100644
> > index 0000000000..e19e431b53
> > --- /dev/null
> > +++ b/bsps/riscv/riscv/config/frdme310arty.cfg
> > @@ -0,0 +1,9 @@
> > +include $(RTEMS_ROOT)/make/custom/default.cfg
> > +RTEMS_CPU = riscv
> > +CPU_CFLAGS = -march=rv32imac -mabi=ilp32
> > +LDFLAGS = -Wl,--gc-sections
> > +CFLAGS_OPTIMIZE_V ?= -O2 -g -ffunction-sections -fdata-sections
> > diff --git a/bsps/riscv/riscv/console/console-config.c b/bsps/riscv/riscv/console/console-config.c
> > index 464b4b0e26..3cd1d89e08 100644
> > --- a/bsps/riscv/riscv/console/console-config.c
> > +++ b/bsps/riscv/riscv/console/console-config.c
> > @@ -28,6 +28,11 @@
> >  #include <libfdt.h>
> >  #include <string.h>
> > +#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0
> > +#include <bsp/fe310-uart.h>
> > +fe310_uart_context driver_context;
> > +#endif
> >  #if RISCV_ENABLE_HTIF_SUPPORT != 0
> >  static htif_console_context htif_console_instance;
> >  #endif
> > @@ -59,7 +64,18 @@ static int riscv_get_console_node(const void *fdt)
> >      stdout_path = "";
> > +  int root;
> > +  int soc;
> > +  root = fdt_path_offset(fdt, "/");
> > +  soc = fdt_subnode_offset(fdt, root, "soc");
> > +  int offset=fdt_subnode_offset(fdt, soc,stdout_path);
> > +  return offset;
> > +#else
> >    return fdt_path_offset(fdt, stdout_path);
> > +#endif
> >  #if RISCV_CONSOLE_MAX_NS16550_DEVICES > 0
> > @@ -193,6 +209,27 @@ static void riscv_console_probe(void)
> >  #endif
> > +    if (RISCV_CONSOLE_IS_COMPATIBLE(compat, compat_len, "sifive,uart0")) {
> > +      fe310_uart_context *ctx ;
> > +      ctx=&driver_context;
> > +      ctx->regs = (uintptr_t) riscv_fdt_get_address(fdt, node);
> > +      if (ctx->regs == 0)
> > +        bsp_fatal(RISCV_FATAL_NO_NS16550_REG_IN_DEVICE_TREE);
> > +      if (node == console_node) {
> > +        riscv_console.context = &ctx->base;
> > +        riscv_console.putchar = fe310_console_putchar;
> > +        riscv_console.getchar = fe310_uart_read;
> > +      rtems_termios_device_context_initialize(&ctx->base, "FE310UART");
> > +#endif
> >      node = fdt_next_node(fdt, node, NULL);
> > @@ -224,6 +261,10 @@ rtems_status_code console_initialize(
> >    size_t i;
> >  #endif
> > +  char path[] = "/dev/ttyS0";
> > +#endif
> >    rtems_termios_initialize();
> > @@ -255,6 +296,22 @@ rtems_status_code console_initialize(
> >  #endif
> > +  fe310_uart_context * ctx = &driver_context;
> > +  rtems_termios_device_install(
> > +    path,
> > +    &fe310_uart_handler,
> > +    NULL,
> > +    &ctx->base
> > +  if (&ctx->base == riscv_console.context) {
> > +    link(path, CONSOLE_DEVICE_NAME);
> > +#endif
> >    return RTEMS_SUCCESSFUL;
> > diff --git a/bsps/riscv/riscv/console/fe310-uart.c b/bsps/riscv/riscv/console/fe310-uart.c
> > index 0000000000..06b312f2d1
> > --- /dev/null
> > +++ b/bsps/riscv/riscv/console/fe310-uart.c
> > @@ -0,0 +1,100 @@
> > + * Copyright (c) 2019 Sachin Ghadi <sachin.ghadi at sifive.com>
> > + * Copyright (c) 2019 Pragnesh Patel <pragnesh.patel at sifive.com>
> > + * The license and distribution terms for this file may be
> > + * found in the file LICENSE in this distribution or at
> > + * http://www.rtems.org/license/LICENSE.
> > +#include <bsp/riscv.h>
> > +#include <assert.h>
> > +static void irq_handler(void *arg)
> > +       /*TODO*/
> > +int fe310_uart_read(rtems_termios_device_context *base)
> > +       fe310_uart_context * ctx = (fe310_uart_context*) base;
> > +         size_t i;
> > +         if (((ctx->regs->rxdata) & TXRXREADY) != 0) {
> > +           return -1;
> > +         } else {
> > +           return ctx->regs->rxdata;
> > +static ssize_t fe310_uart_write (
> > +  rtems_termios_device_context  *base,
> > +  const char                    *buf,
> > +  size_t                        n
> > +  size_t i;
> > +  rtems_status_code sc;
> > +  (ctx->regs)->div = riscv_get_core_frequency()/ 115200 - 1;
> > +  (ctx->regs)->txctrl |= 1;
> > +  (ctx->regs)->rxctrl |= 1;
> > +  for (i = 0; i < n; ++i) {
> > +    while (((ctx->regs->txdata) & TXRXREADY) != 0) {
> > +    ctx->regs->txdata = buf[i];
> > +  return n;
> > +void fe310_console_putchar(rtems_termios_device_context * context,char c)
> > +       fe310_uart_write ( context, &c,1);
> > +void console_context_init(
> > +  int device_tree_node
> > +       /*TODO*/
> > +static bool fe310_uart_first_open (
> > +  rtems_termios_tty             *tty,
> > +  struct termios                *term,
> > +  rtems_libio_open_close_args_t *args
> > +  fe310_uart_context * ctx;
> > +  /* Configure GPIO to be UART */
> > +  sc = rtems_termios_set_initial_baud (tty, B115200);
> > +  if ( sc != RTEMS_SUCCESSFUL ) {
> > +    return false;
> > +  /* Set up a baud rate and enable tx and rx */
> > +  ctx = (fe310_uart_context *) base;
> > +  return true;
> > +const rtems_termios_device_handler fe310_uart_handler = {
> > +  .first_open = fe310_uart_first_open,
> > +  .write = fe310_uart_write,
> > +  .poll_read = fe310_uart_read,
> > +  .mode = TERMIOS_POLLED
> > diff --git a/bsps/riscv/riscv/dts/frdme310arty.dts b/bsps/riscv/riscv/dts/frdme310arty.dts
> > index 0000000000..a7a216de28
> > --- /dev/null
> > +++ b/bsps/riscv/riscv/dts/frdme310arty.dts
> > @@ -0,0 +1,130 @@
> > +/dts-v1/;
> > +       #address-cells = <1>;
> > +       #size-cells = <1>;
> > +       compatible = "SiFive,FE310G-dev", "fe310-dev", "sifive-dev";
> > +       model = "SiFive,FE310G";
> > +       L20: chosen {
> > +               stdout-path = "serial at 20000000";
> > +       L17: cpus {
> > +               #size-cells = <0>;
> > +               L6: cpu at 0 {
> > +                       clocks = <&refclk>;
> > +                       compatible = "sifive,rocket0", "riscv";
> > +                       device_type = "cpu";
> > +                       i-cache-block-size = <64>;
> > +                       i-cache-sets = <128>;
> > +                       i-cache-size = <16384>;
> > +                       next-level-cache = <&L12>;
> > +                       reg = <0>;
> > +                       riscv,isa = "rv32imac";
> > +                       sifive,dtim = <&L5>;
> > +                       sifive,itim = <&L4>;
> > +                       status = "okay";
> > +                       timebase-frequency = <1000000>;
> > +                       L3: interrupt-controller {
> > +                               #interrupt-cells = <1>;
> > +                               compatible = "riscv,cpu-intc";
> > +                               interrupt-controller;
> > +       L16: soc {
> > +               compatible = "SiFive,FE310G-soc", "fe310-soc", "sifive-soc", "simple-bus";
> > +               ranges;
> > +    L19: tlclk {
> > +                       #clock-cells = <0>;
> > +                       clock-frequency = <32500000>;
> > +                       clock-output-names = "tlclk";
> > +                       compatible = "fixed-clock";
> > +               refclk: refclk {
> > +                       clock-frequency = <66666666>;
> > +                       clock-output-names = "refclk";
> > +               L1: clint at 2000000 {
> > +                       compatible = "riscv,clint0";
> > +                       interrupts-extended = <&L3 3 &L3 7>;
> > +                       reg = <0x2000000 0x10000>;
> > +                       reg-names = "control";
> > +               L2: debug-controller at 0 {
> > +                       compatible = "sifive,debug-013", "riscv,debug-013";
> > +                       interrupts-extended = <&L3 65535>;
> > +                       reg = <0x0 0x1000>;
> > +               L5: dtim at 80000000 {
> > +                       compatible = "sifive,dtim0";
> > +                       reg = <0x80000000 0x10000>;
> > +                       reg-names = "mem";
> > +               L8: error-device at 3000 {
> > +                       compatible = "sifive,error0";
> > +                       reg = <0x3000 0x1000>;
> > +               L9: global-external-interrupts {
> > +                       interrupt-parent = <&L0>;
> > +                       interrupts = <1 2 3 4>;
> > +               L13: gpio at 20002000 {
> > +                       compatible = "sifive,gpio0";
> > +                       interrupts = <7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22>;
> > +                       reg = <0x20002000 0x1000>;
> > +               L0: interrupt-controller at c000000 {
> > +                       compatible = "riscv,plic0";
> > +                       interrupts-extended = <&L3 11>;
> > +                       reg = <0xc000000 0x4000000>;
> > +                       riscv,max-priority = <7>;
> > +                       riscv,ndev = <26>;
> > +               L4: itim at 8000000 {
> > +                       compatible = "sifive,itim0";
> > +                       reg = <0x8000000 0x4000>;
> > +               L10: local-external-interrupts-0 {
> > +                       interrupt-parent = <&L3>;
> > +                       interrupts = <16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31>;
> > +               L14: pwm at 20005000 {
> > +                       compatible = "sifive,pwm0";
> > +                       interrupts = <23 24 25 26>;
> > +                       reg = <0x20005000 0x1000>;
> > +               L11: serial at 20000000 {
> > +                       compatible = "sifive,uart0";
> > +                       interrupts = <5>;
> > +                       reg = <0x20000000 0x1000>;
> > +               L12: spi at 20004000 {
> > +                       compatible = "sifive,spi0";
> > +                       interrupts = <6>;
> > +                       reg = <0x20004000 0x1000 0x40000000 0x20000000>;
> > +                       reg-names = "control", "mem";
> > +               L7: teststatus at 4000 {
> > +                       compatible = "sifive,test0";
> > +                       reg = <0x4000 0x1000>;
> > diff --git a/bsps/riscv/riscv/include/bsp/fe310-uart.h b/bsps/riscv/riscv/include/bsp/fe310-uart.h
> > index 0000000000..065e12a7ce
> > --- /dev/null
> > +++ b/bsps/riscv/riscv/include/bsp/fe310-uart.h
> > @@ -0,0 +1,42 @@
> > +#ifndef FE310_UART_H
> > +#define FE310_UART_H
> > +#define TXRXREADY (1 << 31)
> > +#include <rtems/termiostypes.h>
> > +#include <rtems/irq.h>
> > +typedef struct {
> > +  uint32_t txdata;
> > +  uint32_t rxdata;
> > +  uint32_t txctrl;
> > +  uint32_t rxctrl;
> > +  uint32_t ie;
> > +  uint32_t ip;
> > +  uint32_t div;
> > +} fe310_uart_t;
> > +/* Low-level driver specific data structure */
> > +typedef struct {
> > +  rtems_termios_device_context base;
> > +  const char *device_name;
> > +  volatile fe310_uart_t *regs;
> > +} fe310_uart_context;
> > +int fe310_uart_read(rtems_termios_device_context *base);
> > +void fe310_console_putchar(rtems_termios_device_context * context,char c);
> > +extern const rtems_termios_device_handler fe310_uart_handler;
> > +extern fe310_uart_context driver_context;
> > +#endif /* FE310_UART_H */
> > diff --git a/bsps/riscv/riscv/include/bsp/riscv.h b/bsps/riscv/riscv/include/bsp/riscv.h
> > index 374d5f7a77..f2f1a597ca 100644
> > --- a/bsps/riscv/riscv/include/bsp/riscv.h
> > +++ b/bsps/riscv/riscv/include/bsp/riscv.h
> > @@ -38,6 +38,10 @@ extern volatile RISCV_CLINT_regs *riscv_clint;
> >  void *riscv_fdt_get_address(const void *fdt, int node);
> > +uint32_t riscv_get_core_frequency(void);
> > +#endif
> >  #ifdef RTEMS_SMP
> >  extern uint32_t riscv_hart_count;
> >  #else
> > diff --git a/bsps/riscv/riscv/start/bspstart.c b/bsps/riscv/riscv/start/bspstart.c
> > index d4c4e1ff7f..a462bbe6e1 100644
> > --- a/bsps/riscv/riscv/start/bspstart.c
> > +++ b/bsps/riscv/riscv/start/bspstart.c
> > @@ -30,6 +30,11 @@
> >  #include <libfdt.h>
> > +#include <string.h>
> > +unsigned int riscv_core_freq;
> > +#endif
> > @@ -161,8 +166,55 @@ uint32_t riscv_get_hart_index_by_phandle(uint32_t phandle)
> >    return UINT32_MAX;
> > +static uint32_t get_core_frequency(void)
> > +       uint32_t node;
> > +       const char *fdt=bsp_fdt_get();
> > +  char *tlclk;
> > +       uint32_t len;
> > +  do
> > +    node=fdt_node_offset_by_compatible(fdt, -1,"fixed-clock");
> > +    uint32_t *val=NULL;
> > +    if (node>0)
> > +      tlclk = fdt_getprop(fdt, node, "clock-output-names", &len);
> > +      if (strcmp(tlclk,"tlclk") == 0)
> > +        val = fdt_getprop(fdt, node, "clock-frequency", &len);
> > +                   if(val !=NULL)
> > +                           riscv_core_freq=fdt32_to_cpu(*val);
> > +          break;
> > +         }else
> > +      bsp_fatal(RISCV_FATAL_NO_TLCLOCK_FREQUENCY_IN_DEVICE_TREE);
> > +  } while (node > 0);
> > +       return riscv_core_freq;
> > +inline uint32_t riscv_get_core_frequency(void)
> > +#endif
> >  void bsp_start(void)
> >    riscv_find_harts();
> >    bsp_interrupt_initialize();
> > +       riscv_core_freq=get_core_frequency();
> > +#endif
> > diff --git a/c/src/lib/libbsp/riscv/riscv/Makefile.am b/c/src/lib/libbsp/riscv/riscv/Makefile.am
> > index 34bedf844f..15b0865306 100644
> > --- a/c/src/lib/libbsp/riscv/riscv/Makefile.am
> > +++ b/c/src/lib/libbsp/riscv/riscv/Makefile.am
> > @@ -46,7 +46,11 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-defa
> >  librtemsbsp_a_SOURCES +=../../../../../../bsps/riscv/riscv/clock/clockdrv.c
> >  # Timer
> > +librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-cpucounter.c
> > +#else
> >  librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-stub.c
> > +#endif
> >  # IRQ
> >  librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
> > @@ -60,6 +64,10 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termio
> >  librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/console/console-config.c
> >  librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/console/htif.c
> > +librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/console/fe310-uart.c
> > +#endif
> >  if HAS_SMP
> >  librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/start/bspsmp.c
> >  endif
> > diff --git a/c/src/lib/libbsp/riscv/riscv/configure.ac b/c/src/lib/libbsp/riscv/riscv/configure.ac
> > index b01dee242e..26a3e07e98 100644
> > --- a/c/src/lib/libbsp/riscv/riscv/configure.ac
> > +++ b/c/src/lib/libbsp/riscv/riscv/configure.ac
> > @@ -36,9 +36,14 @@ RTEMS_BSPOPTS_HELP([RISCV_MAXIMUM_EXTERNAL_INTERRUPTS],[maximum number of extern
> >  RTEMS_BSPOPTS_SET([RISCV_ENABLE_HTIF_SUPPORT],[*],[])
> >  RTEMS_BSPOPTS_HELP([RISCV_ENABLE_HTIF_SUPPORT],[enables the HTIF support if defined to a non-zero value, otherwise it is disabled (disabled by default)])
> > +RTEMS_BSPOPTS_SET([RISCV_CONSOLE_MAX_NS16550_DEVICES],[frdme310arty*],[])
> >  RTEMS_BSPOPTS_SET([RISCV_CONSOLE_MAX_NS16550_DEVICES],[*],[2])
> >  RTEMS_BSPOPTS_HELP([RISCV_CONSOLE_MAX_NS16550_DEVICES],[maximum number of NS16550 devices supported by the console driver (2 by default)])
> > +RTEMS_BSPOPTS_SET([RISCV_ENABLE_FRDME310ARTY_SUPPORT],[frdme310arty*],[1])
> > +RTEMS_BSPOPTS_SET([RISCV_ENABLE_FRDME310ARTY_SUPPORT],[*],[])
> > +RTEMS_BSPOPTS_HELP([RISCV_ENABLE_FRDME310ARTY_SUPPORT],[enables support sifive Freedom E310 Arty board if defined to a non-zero value,otherwise it is disabled (disabled by default)])
> >  RTEMS_BSP_CLEANUP_OPTIONS
> >  case "${RTEMS_BSP}" in
> > @@ -53,13 +58,22 @@ case "${RTEMS_BSP}" in
> >  esac
> > +case "${RTEMS_BSP}" in
> > +  frdm*310arty)
> > +    RISCV_RAM_REGION_SIZE_DEFAULT=0x10000000
> > +    RISCV_RAM_REGION_SIZE_DEFAULT=0x04000000
> > +esac
> >  AC_DEFUN([RISCV_LINKCMD],[
> >  AC_ARG_VAR([$1],[$2])dnl
> >  [$1]=[$]{[$1]:-[$3]}
> >  RISCV_LINKCMD([RISCV_RAM_REGION_BEGIN],[begin of the RAM region for linker command file (default is 0x70000000 for 64-bit with -mcmodel=medlow and 0x80000000 for all other)],[${RISCV_RAM_REGION_BEGIN_DEFAULT}])
> > -RISCV_LINKCMD([RISCV_RAM_REGION_SIZE],[size of the RAM region for linker command file (default 64MiB)],[0x04000000])
> > +RISCV_LINKCMD([RISCV_RAM_REGION_SIZE],[size of the RAM region for linker command file (default is 256 MiB for frdme310arty and 64 MiB for all other)],[${RISCV_RAM_REGION_SIZE_DEFAULT}])
> No need for this change?
Arty A7 100T has a 256 MB of RAM. So,  do you want me to make
RISCV_RAM_REGION_SIZE to default 64 MB for frdme310arty?
> >  AC_CONFIG_FILES([
> >  Makefile
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
