How to build multiple BSPs with waf?
Sebastian Huber
Fri Oct 11 11:40:44 UTC 2019
On 05/10/2019 01:50, Chris Johns wrote:
> On 4/10/19 11:33 pm, Sebastian Huber wrote:
>> Hello,
>> I tried to figure how a standard waf build can be configured so that out-of-tree
>> or multiple build trees can be used. I couldn't get this working.
>> The Samba project seems to have support for out-of-tree builds:
>> https://wiki.samba.org/index.php/Waf#Out_of_tree_builds
>> However, this '-b' option is not present in a standard waf.
> You would need to look for the additional options SAMBA must have added.
This looks like a project for the future.
>> The libbsd uses a common build tree for a list of arch/bsp combinations. This
>> seems to be quite a resource hungry solution. For example, I am not able to
>> build two BSPs with this approach on Windows/MSYS2.
> What resources are you referring too, disk space, memory?
When I build two BSPs on Windows/MSYS2 I get this error:
[1940/1940] Linking
build/powerpc-rtems5-qoriq_e6500_32-default/zerocopy01.exe
Waf: Leaving directory
`/c/rtems/home/rtems-libbsd/build/powerpc-rtems5-qoriq_e6500_32-default'
'build-powerpc-rtems5-qoriq_e6500_32-default' finished successfully
(3m17.050s)
Waf: Entering directory
`/c/rtems/home/rtems-libbsd/build/powerpc-rtems5-qoriq_e6500_64-default'
[1/4] Creating
build/powerpc-rtems5-qoriq_e6500_64-default/build-include/rtems/bsd/modules.h
[2/4] Compiling rtemsbsd/rtems/generate_kvm_symbols
[3/4] Compiling testsuite/include/rtems/bsd/test/network-config.h.in
[4/4] Compiling
build/powerpc-rtems5-qoriq_e6500_64-default/rtemsbsd/rtems/rtems-kernel-kvm-symbols.c
Build failed
Traceback (most recent call last):
File
"/c/rtems/home/rtems-libbsd/.waf3-2.0.13-4c5a17779813574907c253ab5418388d/waflib/Task.py",
line 176, in process
ret=self.run()
File "<string>", line 27, in f
File "/c/rtems/home/rtems-libbsd/rtems_waf/rtems.py", line 635, in
exec_command
ret = super(self.__class__, self).exec_command(cmd, **kw)
exec_command
exec_command
[Previous line repeated 326 more times]
File "/c/rtems/home/rtems-libbsd/rtems_waf/rtems.py", line 624, in
exec_command
if not isinstance(cmd, str) and len(str(cmd)) > 8192:
RecursionError: maximum recursion depth exceeded while getting the str
of an object
Building the BSPs one after another works well.
>> Is there already a plan to build multiple BSPs (or one BSP with different
>> options) with waf?
> Amar built more than one BSP, one after the other and so does rtems_waf. I have
> not seen anything that would build a single BSP with different options using a
> single configure command.
Ok, I figured it out more or less how you can build variants with waf.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
