[PATCH v5] riscv: add freedom E310 Arty A7 bsp
Pragnesh Patel
pragnesh.patel at sifive.com
Tue Oct 22 10:19:07 UTC 2019
Sorry, I forgot to add "Changes in v5", please ignore this v5.
-----Original Message-----
From: Pragnesh Patel <pragnesh.patel at sifive.com>
Sent: 22 October 2019 15:45
To: rtems-devel at rtems.org; Sachin Ghadi <sachin.ghadi at sifive.com>
Cc: Pragnesh Patel <pragnesh.patel at sifive.com>
Subject: [PATCH v5] riscv: add freedom E310 Arty A7 bsp
Added support for Sifive Freedom FE310 soc on Arty A7 FPGA board.
Update #3785.
Signed-off-by: Pragnesh Patel <pragnesh.patel at sifive.com>
bsps/include/bsp/fatal.h | 3 +-
bsps/riscv/riscv/clock/clockdrv.c | 16 ++-
bsps/riscv/riscv/config/frdme310arty.cfg | 9 ++
bsps/riscv/riscv/console/console-config.c | 57 ++++++++++
bsps/riscv/riscv/console/fe310-uart.c | 118 ++++++++++++++++++++
bsps/riscv/riscv/dts/frdme310arty.dts | 130 ++++++++++++++++++++++
bsps/riscv/riscv/include/bsp/fe310-uart.h | 61 ++++++++++
bsps/riscv/riscv/include/bsp/riscv.h | 4 +
bsps/riscv/riscv/start/bspstart.c | 52 +++++++++
c/src/lib/libbsp/riscv/riscv/Makefile.am | 8 ++
c/src/lib/libbsp/riscv/riscv/configure.ac | 16 ++-
11 files changed, 467 insertions(+), 7 deletions(-) create mode 100644 bsps/riscv/riscv/config/frdme310arty.cfg
create mode 100644 bsps/riscv/riscv/console/fe310-uart.c
create mode 100644 bsps/riscv/riscv/dts/frdme310arty.dts
create mode 100644 bsps/riscv/riscv/include/bsp/fe310-uart.h
diff --git a/bsps/include/bsp/fatal.h b/bsps/include/bsp/fatal.h index fae5461699..3f8e1eb591 100644
--- a/bsps/include/bsp/fatal.h
+++ b/bsps/include/bsp/fatal.h
@@ -152,7 +152,8 @@ typedef enum {
RISCV_FATAL_INVALID_PLIC_NDEV_IN_DEVICE_TREE,
RISCV_FATAL_TOO_LARGE_PLIC_NDEV_IN_DEVICE_TREE,
RISCV_FATAL_INVALID_INTERRUPT_AFFINITY,
- RISCV_FATAL_NO_NS16550_INTERRUPTS_IN_DEVICE_TREE
+ RISCV_FATAL_NO_NS16550_INTERRUPTS_IN_DEVICE_TREE,
+ RISCV_FATAL_NO_TLCLOCK_FREQUENCY_IN_DEVICE_TREE
} bsp_fatal_code;
RTEMS_NO_RETURN static inline void
diff --git a/bsps/riscv/riscv/clock/clockdrv.c b/bsps/riscv/riscv/clock/clockdrv.c
index 7e6034d4d1..d085b6bd95 100644
--- a/bsps/riscv/riscv/clock/clockdrv.c
+++ b/bsps/riscv/riscv/clock/clockdrv.c
@@ -130,15 +130,21 @@ static uint32_t riscv_clock_get_timecount(struct timecounter *base) static uint32_t riscv_clock_get_timebase_frequency(const void *fdt) {
int node;
- const uint32_t *val;
- int len;
+ const fdt32_t *val;
+ int len=0;
node = fdt_path_offset(fdt, "/cpus");
- val = fdt_getprop(fdt, node, "timebase-frequency", &len);
+ val = (fdt32_t *) fdt_getprop(fdt, node, "timebase-frequency", &len);
if (val == NULL || len < 4) {
- bsp_fatal(RISCV_FATAL_NO_TIMEBASE_FREQUENCY_IN_DEVICE_TREE);
+ int cpu0 = fdt_subnode_offset(fdt, node, "cpu at 0");
+ val = (fdt32_t *) fdt_getprop(fdt, cpu0, "timebase-frequency",
+ &len);
+ if (val == NULL || len < 4) {
+ bsp_fatal(RISCV_FATAL_NO_TIMEBASE_FREQUENCY_IN_DEVICE_TREE);
return fdt32_to_cpu(*val);
diff --git a/bsps/riscv/riscv/config/frdme310arty.cfg b/bsps/riscv/riscv/config/frdme310arty.cfg
new file mode 100644
index 0000000000..e19e431b53
--- /dev/null
+++ b/bsps/riscv/riscv/config/frdme310arty.cfg
@@ -0,0 +1,9 @@
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = riscv
+CPU_CFLAGS = -march=rv32imac -mabi=ilp32
+LDFLAGS = -Wl,--gc-sections
+CFLAGS_OPTIMIZE_V ?= -O2 -g -ffunction-sections -fdata-sections
diff --git a/bsps/riscv/riscv/console/console-config.c b/bsps/riscv/riscv/console/console-config.c
index 464b4b0e26..3cd1d89e08 100644
--- a/bsps/riscv/riscv/console/console-config.c
+++ b/bsps/riscv/riscv/console/console-config.c
@@ -28,6 +28,11 @@
#include <libfdt.h>
+#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0 #include <bsp/fe310-uart.h>
+fe310_uart_context driver_context; #endif
#if RISCV_ENABLE_HTIF_SUPPORT != 0
static htif_console_context htif_console_instance; #endif @@ -59,7 +64,18 @@ static int riscv_get_console_node(const void *fdt)
stdout_path = "";
+ int root;
+ int soc;
+ root = fdt_path_offset(fdt, "/");
+ soc = fdt_subnode_offset(fdt, root, "soc");
+ int offset=fdt_subnode_offset(fdt, soc,stdout_path);
+ return offset;
+#else
return fdt_path_offset(fdt, stdout_path);
+#endif
#if RISCV_CONSOLE_MAX_NS16550_DEVICES > 0 @@ -193,6 +209,27 @@ static void riscv_console_probe(void)
#endif
+ if (RISCV_CONSOLE_IS_COMPATIBLE(compat, compat_len, "sifive,uart0")) {
+ fe310_uart_context *ctx ;
+ ctx=&driver_context;
+ ctx->regs = (uintptr_t) riscv_fdt_get_address(fdt, node);
+ if (ctx->regs == 0)
+ bsp_fatal(RISCV_FATAL_NO_NS16550_REG_IN_DEVICE_TREE);
+ if (node == console_node) {
+ riscv_console.context = &ctx->base;
+ riscv_console.putchar = fe310_console_putchar;
+ riscv_console.getchar = fe310_uart_read;
+ rtems_termios_device_context_initialize(&ctx->base, "FE310UART");
+#endif
node = fdt_next_node(fdt, node, NULL);
@@ -224,6 +261,10 @@ rtems_status_code console_initialize(
size_t i;
#endif
+ char path[] = "/dev/ttyS0";
+#endif
rtems_termios_initialize();
@@ -255,6 +296,22 @@ rtems_status_code console_initialize(
#endif
+ fe310_uart_context * ctx = &driver_context;
+ rtems_termios_device_install(
+ path,
+ &fe310_uart_handler,
+ NULL,
+ &ctx->base
+ if (&ctx->base == riscv_console.context) {
+ link(path, CONSOLE_DEVICE_NAME);
+#endif
return RTEMS_SUCCESSFUL;
diff --git a/bsps/riscv/riscv/console/fe310-uart.c b/bsps/riscv/riscv/console/fe310-uart.c
index 0000000000..a8e87f452c
--- /dev/null
+++ b/bsps/riscv/riscv/console/fe310-uart.c
@@ -0,0 +1,118 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (c) 2019 Pragnesh Patel <pragnesh.patel at sifive.com>
+ * Copyright (c) 2019 Sachin Ghadi <sachin.ghadi at sifive.com>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
+TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
+PURPOSE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
+CONTRIBUTORS BE
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
+BUSINESS
+ * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
+IN
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+OTHERWISE)
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
+OF THE
+#include <bsp/riscv.h>
+#include <bsp/fe310-uart.h>
+#include <assert.h>
+static void irq_handler(void *arg)
+ /*TODO*/
+int fe310_uart_read(rtems_termios_device_context *base) {
+ fe310_uart_context * ctx = (fe310_uart_context*) base;
+ size_t i;
+ if (((ctx->regs->rxdata) & TXRXREADY) != 0) {
+ return -1;
+ } else {
+ return ctx->regs->rxdata;
+static ssize_t fe310_uart_write (
+ rtems_termios_device_context *base,
+ const char *buf,
+ size_t n
+ size_t i;
+ rtems_status_code sc;
+ (ctx->regs)->div = riscv_get_core_frequency()/ 115200 - 1;
+ (ctx->regs)->txctrl |= 1; (ctx->regs)->rxctrl |= 1;
+ for (i = 0; i < n; ++i) {
+ while (((ctx->regs->txdata) & TXRXREADY) != 0) {
+ ctx->regs->txdata = buf[i];
+ return n;
+void fe310_console_putchar(rtems_termios_device_context * context,char
+c) {
+ fe310_uart_write ( context, &c,1);
+void console_context_init(
+ int device_tree_node
+ /*TODO*/
+static bool fe310_uart_first_open (
+ rtems_termios_tty *tty,
+ struct termios *term,
+ rtems_libio_open_close_args_t *args
+ fe310_uart_context * ctx;
+ /* Configure GPIO to be UART */
+ sc = rtems_termios_set_initial_baud (tty, B115200); if ( sc !=
+ RTEMS_SUCCESSFUL ) {
+ return false;
+ /* Set up a baud rate and enable tx and rx */
+ ctx = (fe310_uart_context *) base;
+ (ctx->regs)->rxctrl |= 1;
+ return true;
+const rtems_termios_device_handler fe310_uart_handler = {
+ .first_open = fe310_uart_first_open,
+ .write = fe310_uart_write,
+ .poll_read = fe310_uart_read,
+ .mode = TERMIOS_POLLED
diff --git a/bsps/riscv/riscv/dts/frdme310arty.dts b/bsps/riscv/riscv/dts/frdme310arty.dts
index 0000000000..a7a216de28
--- /dev/null
+++ b/bsps/riscv/riscv/dts/frdme310arty.dts
@@ -0,0 +1,130 @@
+/dts-v1/;
+ #address-cells = <1>;
+ #size-cells = <1>;
+ compatible = "SiFive,FE310G-dev", "fe310-dev", "sifive-dev";
+ model = "SiFive,FE310G";
+ L20: chosen {
+ stdout-path = "serial at 20000000";
+ L17: cpus {
+ #size-cells = <0>;
+ L6: cpu at 0 {
+ clocks = <&refclk>;
+ compatible = "sifive,rocket0", "riscv";
+ device_type = "cpu";
+ i-cache-block-size = <64>;
+ i-cache-sets = <128>;
+ i-cache-size = <16384>;
+ next-level-cache = <&L12>;
+ reg = <0>;
+ riscv,isa = "rv32imac";
+ sifive,dtim = <&L5>;
+ sifive,itim = <&L4>;
+ status = "okay";
+ timebase-frequency = <1000000>;
+ L3: interrupt-controller {
+ #interrupt-cells = <1>;
+ compatible = "riscv,cpu-intc";
+ interrupt-controller;
+ L16: soc {
+ compatible = "SiFive,FE310G-soc", "fe310-soc", "sifive-soc", "simple-bus";
+ ranges;
+ L19: tlclk {
+ #clock-cells = <0>;
+ clock-frequency = <32500000>;
+ clock-output-names = "tlclk";
+ compatible = "fixed-clock";
+ refclk: refclk {
+ clock-frequency = <66666666>;
+ clock-output-names = "refclk";
+ L1: clint at 2000000 {
+ compatible = "riscv,clint0";
+ interrupts-extended = <&L3 3 &L3 7>;
+ reg = <0x2000000 0x10000>;
+ reg-names = "control";
+ L2: debug-controller at 0 {
+ compatible = "sifive,debug-013", "riscv,debug-013";
+ interrupts-extended = <&L3 65535>;
+ reg = <0x0 0x1000>;
+ L5: dtim at 80000000 {
+ compatible = "sifive,dtim0";
+ reg = <0x80000000 0x10000>;
+ reg-names = "mem";
+ L8: error-device at 3000 {
+ compatible = "sifive,error0";
+ reg = <0x3000 0x1000>;
+ L9: global-external-interrupts {
+ interrupt-parent = <&L0>;
+ interrupts = <1 2 3 4>;
+ L13: gpio at 20002000 {
+ compatible = "sifive,gpio0";
+ interrupts = <7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22>;
+ reg = <0x20002000 0x1000>;
+ L0: interrupt-controller at c000000 {
+ compatible = "riscv,plic0";
+ interrupts-extended = <&L3 11>;
+ reg = <0xc000000 0x4000000>;
+ riscv,max-priority = <7>;
+ riscv,ndev = <26>;
+ L4: itim at 8000000 {
+ compatible = "sifive,itim0";
+ reg = <0x8000000 0x4000>;
+ L10: local-external-interrupts-0 {
+ interrupt-parent = <&L3>;
+ interrupts = <16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31>;
+ L14: pwm at 20005000 {
+ compatible = "sifive,pwm0";
+ interrupts = <23 24 25 26>;
+ reg = <0x20005000 0x1000>;
+ L11: serial at 20000000 {
+ compatible = "sifive,uart0";
+ interrupts = <5>;
+ reg = <0x20000000 0x1000>;
+ L12: spi at 20004000 {
+ compatible = "sifive,spi0";
+ interrupts = <6>;
+ reg = <0x20004000 0x1000 0x40000000 0x20000000>;
+ reg-names = "control", "mem";
+ L7: teststatus at 4000 {
+ compatible = "sifive,test0";
+ reg = <0x4000 0x1000>;
diff --git a/bsps/riscv/riscv/include/bsp/fe310-uart.h b/bsps/riscv/riscv/include/bsp/fe310-uart.h
index 0000000000..c6c6fcb876
--- /dev/null
+++ b/bsps/riscv/riscv/include/bsp/fe310-uart.h
@@ -0,0 +1,61 @@
+ * Copyright (C) 2019 Pragnesh Patel <pragnesh.patel at sifive.com>
+ * are met:
+TO, THE
+PURPOSE
+CONTRIBUTORS BE
+BUSINESS
+IN
+OTHERWISE)
+OF THE
+#ifndef FE310_UART_H
+#define FE310_UART_H
+#define TXRXREADY (1 << 31)
+#include <rtems/termiostypes.h>
+#include <rtems/irq.h>
+typedef struct {
+ uint32_t txdata;
+ uint32_t rxdata;
+ uint32_t txctrl;
+ uint32_t rxctrl;
+ uint32_t ie;
+ uint32_t ip;
+ uint32_t div;
+} fe310_uart_t;
+/* Low-level driver specific data structure */ typedef struct {
+ rtems_termios_device_context base;
+ const char *device_name;
+ volatile fe310_uart_t *regs;
+} fe310_uart_context;
+int fe310_uart_read(rtems_termios_device_context *base); void
+fe310_console_putchar(rtems_termios_device_context * context,char c);
+extern const rtems_termios_device_handler fe310_uart_handler;
+extern fe310_uart_context driver_context;
+#endif /* FE310_UART_H */
diff --git a/bsps/riscv/riscv/include/bsp/riscv.h b/bsps/riscv/riscv/include/bsp/riscv.h
index 374d5f7a77..f2f1a597ca 100644
--- a/bsps/riscv/riscv/include/bsp/riscv.h
+++ b/bsps/riscv/riscv/include/bsp/riscv.h
@@ -38,6 +38,10 @@ extern volatile RISCV_CLINT_regs *riscv_clint;
void *riscv_fdt_get_address(const void *fdt, int node);
+#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0 uint32_t
+riscv_get_core_frequency(void); #endif
#ifdef RTEMS_SMP
extern uint32_t riscv_hart_count;
#else
diff --git a/bsps/riscv/riscv/start/bspstart.c b/bsps/riscv/riscv/start/bspstart.c
index d4c4e1ff7f..a462bbe6e1 100644
--- a/bsps/riscv/riscv/start/bspstart.c
+++ b/bsps/riscv/riscv/start/bspstart.c
@@ -30,6 +30,11 @@
#include <libfdt.h>
+#include <string.h>
+#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0 unsigned int
+riscv_core_freq; #endif
void *riscv_fdt_get_address(const void *fdt, int node) { @@ -161,8 +166,55 @@ uint32_t riscv_get_hart_index_by_phandle(uint32_t phandle)
return UINT32_MAX;
+#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0 static uint32_t
+get_core_frequency(void) {
+ uint32_t node;
+ const char *fdt=bsp_fdt_get();
+ char *tlclk;
+ uint32_t len;
+ do
+ node=fdt_node_offset_by_compatible(fdt, -1,"fixed-clock");
+ uint32_t *val=NULL;
+ if (node>0)
+ tlclk = fdt_getprop(fdt, node, "clock-output-names", &len);
+ if (strcmp(tlclk,"tlclk") == 0)
+ val = fdt_getprop(fdt, node, "clock-frequency", &len);
+ if(val !=NULL)
+ riscv_core_freq=fdt32_to_cpu(*val);
+ break;
+ }else
+ bsp_fatal(RISCV_FATAL_NO_TLCLOCK_FREQUENCY_IN_DEVICE_TREE);
+ } while (node > 0);
+ return riscv_core_freq;
+inline uint32_t riscv_get_core_frequency(void) {
+#endif
void bsp_start(void)
riscv_find_harts();
bsp_interrupt_initialize();
+ riscv_core_freq=get_core_frequency();
+#endif
diff --git a/c/src/lib/libbsp/riscv/riscv/Makefile.am b/c/src/lib/libbsp/riscv/riscv/Makefile.am
index 34bedf844f..15b0865306 100644
--- a/c/src/lib/libbsp/riscv/riscv/Makefile.am
+++ b/c/src/lib/libbsp/riscv/riscv/Makefile.am
@@ -46,7 +46,11 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-defa
librtemsbsp_a_SOURCES +=../../../../../../bsps/riscv/riscv/clock/clockdrv.c
# Timer
+#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0 librtemsbsp_a_SOURCES +=
+../../../../../../bsps/shared/dev/btimer/btimer-cpucounter.c
+#else
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-stub.c
+#endif
# IRQ
librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
@@ -60,6 +64,10 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termio
librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/console/console-config.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/console/htif.c
+../../../../../../bsps/riscv/riscv/console/fe310-uart.c
+#endif
if HAS_SMP
librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/start/bspsmp.c
endif
diff --git a/c/src/lib/libbsp/riscv/riscv/configure.ac b/c/src/lib/libbsp/riscv/riscv/configure.ac
index b01dee242e..26a3e07e98 100644
--- a/c/src/lib/libbsp/riscv/riscv/configure.ac
+++ b/c/src/lib/libbsp/riscv/riscv/configure.ac
@@ -36,9 +36,14 @@ RTEMS_BSPOPTS_HELP([RISCV_MAXIMUM_EXTERNAL_INTERRUPTS],[maximum number of extern
RTEMS_BSPOPTS_SET([RISCV_ENABLE_HTIF_SUPPORT],[*],[])
RTEMS_BSPOPTS_HELP([RISCV_ENABLE_HTIF_SUPPORT],[enables the HTIF support if defined to a non-zero value, otherwise it is disabled (disabled by default)])
+RTEMS_BSPOPTS_SET([RISCV_CONSOLE_MAX_NS16550_DEVICES],[frdme310arty*],[
RTEMS_BSPOPTS_SET([RISCV_CONSOLE_MAX_NS16550_DEVICES],[*],[2])
RTEMS_BSPOPTS_HELP([RISCV_CONSOLE_MAX_NS16550_DEVICES],[maximum number of NS16550 devices supported by the console driver (2 by default)])
+RTEMS_BSPOPTS_SET([RISCV_ENABLE_FRDME310ARTY_SUPPORT],[frdme310arty*],[
+1])
+RTEMS_BSPOPTS_SET([RISCV_ENABLE_FRDME310ARTY_SUPPORT],[*],[])
+RTEMS_BSPOPTS_HELP([RISCV_ENABLE_FRDME310ARTY_SUPPORT],[enables support
+sifive Freedom E310 Arty board if defined to a non-zero value,otherwise
+it is disabled (disabled by default)])
RTEMS_BSP_CLEANUP_OPTIONS
case "${RTEMS_BSP}" in
@@ -53,13 +58,22 @@ case "${RTEMS_BSP}" in
esac
+case "${RTEMS_BSP}" in
+ frdm*310arty)
+ RISCV_RAM_REGION_SIZE_DEFAULT=0x10000000
+ RISCV_RAM_REGION_SIZE_DEFAULT=0x04000000
+esac
AC_DEFUN([RISCV_LINKCMD],[
AC_ARG_VAR([$1],[$2])dnl
[$1]=[$]{[$1]:-[$3]}
RISCV_LINKCMD([RISCV_RAM_REGION_BEGIN],[begin of the RAM region for linker command file (default is 0x70000000 for 64-bit with -mcmodel=medlow and 0x80000000 for all other)],[${RISCV_RAM_REGION_BEGIN_DEFAULT}])
-RISCV_LINKCMD([RISCV_RAM_REGION_SIZE],[size of the RAM region for linker command file (default 64MiB)],[0x04000000])
+RISCV_LINKCMD([RISCV_RAM_REGION_SIZE],[size of the RAM region for
+linker command file (default is 256 MiB for frdme310arty and 64 MiB for
+all other)],[${RISCV_RAM_REGION_SIZE_DEFAULT}])
AC_CONFIG_FILES([
Makefile
2.17.1
