[PATCH v5] riscv: add freedom E310 Arty A7 bsp
    Pragnesh Patel
    pragnesh.patel at sifive.com
    Tue Oct 22 10:20:05 UTC 2019
Added support for Sifive Freedom FE310 soc on Arty A7 FPGA board.
Update #3785.
Signed-off-by: Pragnesh Patel <pragnesh.patel at sifive.com>
Changes in v5:
  - Added BSD-2-Clause LICENSE for the new code
Changes in v4:
  - Revert fdt32_t *val to const in riscv_clock_get_timebase_frequency()
  - make RISCV_ENABLE_FRDME310ARTY_SUPPORT consistent all over the code
  - Revert to the default configuration for riscv/configure.ac
  - Added riscv/config/frdme310arty.cfg as a new riscv config
Changes in v3:
  - Remove bsps/riscv/frdme310arty/ directory and added support for
    Freedom FE310 soc in common bsps/riscv/riscv/ directory
  - Added #define RISCV_ENABLE_FRDME310ARTY_SUPPORT in configure.ac
    to enable support for FE310
  - Change the RISCV_RAM_REGION_SIZE to 256 MB for riscv
Changes in v2:
  bsps/riscv/frdme310arty/btimer/btimer.c
    - Remove the read_csr() function from btimer.c
    - Remove CONFIG_BTIMER_RISCV_GET_MCYCLES macro to get time in
      microseconds
  bsps/riscv/frdme310arty/clock/clockdrv.c
  bsps/riscv/riscv/clock/clockdrv.c
    - Delete both files and Add bsps/riscv/shared/clock/clockdrv.c
    - riscv_clock_get_timebase_frequency(): Get timebase-frequency from
      cpus or cpu at 0 devicetree node because riscv uses "cpus" node and
      frdme310arty uses "cpu at 0" node to look for timebase-frequency
    - Remove rtems_counter_initialize_converter() and
      rtems_timecounter_simple_install() functions
  bsps/riscv/frdme310arty/include/bsp/riscv.h
    - Remove unused frdme310arty_l2c_base;
  bsps/riscv/frdme310arty/start/bsp_fatal_halt.c
  bsps/riscv/riscv/start/bsp_fatal_halt.c
    - Delete this file and Add bsps/riscv/shared/start/bsp_fatal_halt.c
  bsps/riscv/frdme310arty/start/bspstart.c
    - Remove unused function riscv_get_node_byname()
  bsps/riscv/frdme310arty/start/linkcmds.in
    - Use @RISCV_RAM_REGION_BEGIN@ and @RISCV_RAM_REGION_SIZE@ instead of
      hard coded values
  c/src/lib/libbsp/riscv/frdme310arty/Makefile.am
    - librtemsbsp_a_SOURCES -> bsps/riscv/shared/start/bsp_fatal_halt.c
    - librtemsbsp_a_SOURCES -> bsps/riscv/shared/clock/clockdrv.c
  c/src/lib/libbsp/riscv/frdme310arty/configure.ac
    - change RISCV_RAM_REGION_SIZE to default 256MiB
  bsps/riscv/riscv/irq/irq.c
    - Delete this irq.c and it will now use bsps/riscv/shared/irq/irq.c
  c/src/lib/libbsp/riscv/riscv/Makefile.am
    - librtemsbsp_a_SOURCES -> bsps/riscv/shared/irq/irq.c
 bsps/include/bsp/fatal.h                  |   3 +-
 bsps/riscv/riscv/clock/clockdrv.c         |  16 ++-
 bsps/riscv/riscv/config/frdme310arty.cfg  |   9 ++
 bsps/riscv/riscv/console/console-config.c |  57 ++++++++++
 bsps/riscv/riscv/console/fe310-uart.c     | 118 ++++++++++++++++++++
 bsps/riscv/riscv/dts/frdme310arty.dts     | 130 ++++++++++++++++++++++
 bsps/riscv/riscv/include/bsp/fe310-uart.h |  61 ++++++++++
 bsps/riscv/riscv/include/bsp/riscv.h      |   4 +
 bsps/riscv/riscv/start/bspstart.c         |  52 +++++++++
 c/src/lib/libbsp/riscv/riscv/Makefile.am  |   8 ++
 c/src/lib/libbsp/riscv/riscv/configure.ac |  16 ++-
 11 files changed, 467 insertions(+), 7 deletions(-)
 create mode 100644 bsps/riscv/riscv/config/frdme310arty.cfg
 create mode 100644 bsps/riscv/riscv/console/fe310-uart.c
 create mode 100644 bsps/riscv/riscv/dts/frdme310arty.dts
 create mode 100644 bsps/riscv/riscv/include/bsp/fe310-uart.h
diff --git a/bsps/include/bsp/fatal.h b/bsps/include/bsp/fatal.h
index fae5461699..3f8e1eb591 100644
--- a/bsps/include/bsp/fatal.h
+++ b/bsps/include/bsp/fatal.h
@@ -152,7 +152,8 @@ typedef enum {
   RISCV_FATAL_INVALID_PLIC_NDEV_IN_DEVICE_TREE,
   RISCV_FATAL_TOO_LARGE_PLIC_NDEV_IN_DEVICE_TREE,
   RISCV_FATAL_INVALID_INTERRUPT_AFFINITY,
-  RISCV_FATAL_NO_NS16550_INTERRUPTS_IN_DEVICE_TREE
+  RISCV_FATAL_NO_NS16550_INTERRUPTS_IN_DEVICE_TREE,
+  RISCV_FATAL_NO_TLCLOCK_FREQUENCY_IN_DEVICE_TREE
 } bsp_fatal_code;
 RTEMS_NO_RETURN static inline void
diff --git a/bsps/riscv/riscv/clock/clockdrv.c b/bsps/riscv/riscv/clock/clockdrv.c
index 7e6034d4d1..d085b6bd95 100644
--- a/bsps/riscv/riscv/clock/clockdrv.c
+++ b/bsps/riscv/riscv/clock/clockdrv.c
@@ -130,15 +130,21 @@ static uint32_t riscv_clock_get_timecount(struct timecounter *base)
 static uint32_t riscv_clock_get_timebase_frequency(const void *fdt)
   int node;
-  const uint32_t *val;
-  int len;
+  const fdt32_t *val;
+  int len=0;
   node = fdt_path_offset(fdt, "/cpus");
-  val = fdt_getprop(fdt, node, "timebase-frequency", &len);
+  val = (fdt32_t *) fdt_getprop(fdt, node, "timebase-frequency", &len);
   if (val == NULL || len < 4) {
-    bsp_fatal(RISCV_FATAL_NO_TIMEBASE_FREQUENCY_IN_DEVICE_TREE);
+    int cpu0 = fdt_subnode_offset(fdt, node, "cpu at 0");
+    val = (fdt32_t *) fdt_getprop(fdt, cpu0, "timebase-frequency", &len);
+    if (val == NULL || len < 4) {
+      bsp_fatal(RISCV_FATAL_NO_TIMEBASE_FREQUENCY_IN_DEVICE_TREE);
   return fdt32_to_cpu(*val);
diff --git a/bsps/riscv/riscv/config/frdme310arty.cfg b/bsps/riscv/riscv/config/frdme310arty.cfg
new file mode 100644
index 0000000000..e19e431b53
--- /dev/null
+++ b/bsps/riscv/riscv/config/frdme310arty.cfg
@@ -0,0 +1,9 @@
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = riscv
+CPU_CFLAGS = -march=rv32imac -mabi=ilp32
+LDFLAGS = -Wl,--gc-sections
+CFLAGS_OPTIMIZE_V ?= -O2 -g -ffunction-sections -fdata-sections
diff --git a/bsps/riscv/riscv/console/console-config.c b/bsps/riscv/riscv/console/console-config.c
index 464b4b0e26..3cd1d89e08 100644
--- a/bsps/riscv/riscv/console/console-config.c
+++ b/bsps/riscv/riscv/console/console-config.c
@@ -28,6 +28,11 @@
 #include <libfdt.h>
+#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0
+#include <bsp/fe310-uart.h>
+fe310_uart_context driver_context;
+#endif
 #if RISCV_ENABLE_HTIF_SUPPORT != 0
 static htif_console_context htif_console_instance;
 #endif
@@ -59,7 +64,18 @@ static int riscv_get_console_node(const void *fdt)
     stdout_path = "";
+  int root;
+  int soc;
+  root = fdt_path_offset(fdt, "/");
+  soc = fdt_subnode_offset(fdt, root, "soc");
+  int offset=fdt_subnode_offset(fdt, soc,stdout_path);
+  return offset;
+#else
   return fdt_path_offset(fdt, stdout_path);
+#endif
 #if RISCV_CONSOLE_MAX_NS16550_DEVICES > 0
@@ -193,6 +209,27 @@ static void riscv_console_probe(void)
 #endif
+    if (RISCV_CONSOLE_IS_COMPATIBLE(compat, compat_len, "sifive,uart0")) {
+      fe310_uart_context *ctx ;
+      ctx=&driver_context;
+      ctx->regs = (uintptr_t) riscv_fdt_get_address(fdt, node);
+      if (ctx->regs == 0)
+        bsp_fatal(RISCV_FATAL_NO_NS16550_REG_IN_DEVICE_TREE);
+      if (node == console_node) {
+        riscv_console.context = &ctx->base;
+        riscv_console.putchar = fe310_console_putchar;
+        riscv_console.getchar = fe310_uart_read;
+      rtems_termios_device_context_initialize(&ctx->base, "FE310UART");
+#endif
     node = fdt_next_node(fdt, node, NULL);
@@ -224,6 +261,10 @@ rtems_status_code console_initialize(
   size_t i;
 #endif
+  char path[] = "/dev/ttyS0";
+#endif
   rtems_termios_initialize();
@@ -255,6 +296,22 @@ rtems_status_code console_initialize(
 #endif
+  fe310_uart_context * ctx = &driver_context;
+  rtems_termios_device_install(
+    path,
+    &fe310_uart_handler,
+    NULL,
+    &ctx->base
+  if (&ctx->base == riscv_console.context) {
+    link(path, CONSOLE_DEVICE_NAME);
+#endif
   return RTEMS_SUCCESSFUL;
diff --git a/bsps/riscv/riscv/console/fe310-uart.c b/bsps/riscv/riscv/console/fe310-uart.c
index 0000000000..a8e87f452c
--- /dev/null
+++ b/bsps/riscv/riscv/console/fe310-uart.c
@@ -0,0 +1,118 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (c) 2019 Pragnesh Patel <pragnesh.patel at sifive.com>
+ * Copyright (c) 2019 Sachin Ghadi <sachin.ghadi at sifive.com>
+ * are met:
+#include <bsp/riscv.h>
+#include <assert.h>
+static void irq_handler(void *arg)
+	/*TODO*/
+int fe310_uart_read(rtems_termios_device_context *base)
+	fe310_uart_context * ctx = (fe310_uart_context*) base;
+	  size_t i;
+	  if (((ctx->regs->rxdata) & TXRXREADY) != 0) {
+	    return -1;
+	  } else {
+	    return ctx->regs->rxdata;
+static ssize_t fe310_uart_write (
+  rtems_termios_device_context  *base,
+  const char                    *buf,
+  size_t                        n
+  size_t i;
+  rtems_status_code sc;
+  (ctx->regs)->div = riscv_get_core_frequency()/ 115200 - 1;
+  (ctx->regs)->txctrl |= 1;
+  (ctx->regs)->rxctrl |= 1;
+  for (i = 0; i < n; ++i) {
+    while (((ctx->regs->txdata) & TXRXREADY) != 0) {
+    ctx->regs->txdata = buf[i];
+  return n;
+void fe310_console_putchar(rtems_termios_device_context * context,char c)
+	fe310_uart_write ( context, &c,1);
+void console_context_init(
+  int device_tree_node
+	/*TODO*/
+static bool fe310_uart_first_open (
+  rtems_termios_tty             *tty,
+  struct termios                *term,
+  rtems_libio_open_close_args_t *args
+  fe310_uart_context * ctx;
+  /* Configure GPIO to be UART */
+  sc = rtems_termios_set_initial_baud (tty, B115200);
+  if ( sc != RTEMS_SUCCESSFUL ) {
+    return false;
+  /* Set up a baud rate and enable tx and rx */
+  ctx = (fe310_uart_context *) base;
+  return true;
+const rtems_termios_device_handler fe310_uart_handler = {
+  .first_open = fe310_uart_first_open,
+  .write = fe310_uart_write,
+  .poll_read = fe310_uart_read,
+  .mode = TERMIOS_POLLED
diff --git a/bsps/riscv/riscv/dts/frdme310arty.dts b/bsps/riscv/riscv/dts/frdme310arty.dts
index 0000000000..a7a216de28
--- /dev/null
+++ b/bsps/riscv/riscv/dts/frdme310arty.dts
@@ -0,0 +1,130 @@
+/dts-v1/;
+	#address-cells = <1>;
+	#size-cells = <1>;
+	compatible = "SiFive,FE310G-dev", "fe310-dev", "sifive-dev";
+	model = "SiFive,FE310G";
+	L20: chosen {
+		stdout-path = "serial at 20000000";
+	L17: cpus {
+		#size-cells = <0>;
+		L6: cpu at 0 {
+			clocks = <&refclk>;
+			compatible = "sifive,rocket0", "riscv";
+			device_type = "cpu";
+			i-cache-block-size = <64>;
+			i-cache-sets = <128>;
+			i-cache-size = <16384>;
+			next-level-cache = <&L12>;
+			reg = <0>;
+			riscv,isa = "rv32imac";
+			sifive,dtim = <&L5>;
+			sifive,itim = <&L4>;
+			status = "okay";
+			timebase-frequency = <1000000>;
+			L3: interrupt-controller {
+				#interrupt-cells = <1>;
+				compatible = "riscv,cpu-intc";
+				interrupt-controller;
+	L16: soc {
+		compatible = "SiFive,FE310G-soc", "fe310-soc", "sifive-soc", "simple-bus";
+		ranges;
+    L19: tlclk {
+			#clock-cells = <0>;
+			clock-frequency = <32500000>;
+			clock-output-names = "tlclk";
+			compatible = "fixed-clock";
+		refclk: refclk {
+			clock-frequency = <66666666>;
+			clock-output-names = "refclk";
+		L1: clint at 2000000 {
+			compatible = "riscv,clint0";
+			interrupts-extended = <&L3 3 &L3 7>;
+			reg = <0x2000000 0x10000>;
+			reg-names = "control";
+		L2: debug-controller at 0 {
+			compatible = "sifive,debug-013", "riscv,debug-013";
+			interrupts-extended = <&L3 65535>;
+			reg = <0x0 0x1000>;
+		L5: dtim at 80000000 {
+			compatible = "sifive,dtim0";
+			reg = <0x80000000 0x10000>;
+			reg-names = "mem";
+		L8: error-device at 3000 {
+			compatible = "sifive,error0";
+			reg = <0x3000 0x1000>;
+		L9: global-external-interrupts {
+			interrupt-parent = <&L0>;
+			interrupts = <1 2 3 4>;
+		L13: gpio at 20002000 {
+			compatible = "sifive,gpio0";
+			interrupts = <7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22>;
+			reg = <0x20002000 0x1000>;
+		L0: interrupt-controller at c000000 {
+			compatible = "riscv,plic0";
+			interrupts-extended = <&L3 11>;
+			reg = <0xc000000 0x4000000>;
+			riscv,max-priority = <7>;
+			riscv,ndev = <26>;
+		L4: itim at 8000000 {
+			compatible = "sifive,itim0";
+			reg = <0x8000000 0x4000>;
+		L10: local-external-interrupts-0 {
+			interrupt-parent = <&L3>;
+			interrupts = <16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31>;
+		L14: pwm at 20005000 {
+			compatible = "sifive,pwm0";
+			interrupts = <23 24 25 26>;
+			reg = <0x20005000 0x1000>;
+		L11: serial at 20000000 {
+			compatible = "sifive,uart0";
+			interrupts = <5>;
+			reg = <0x20000000 0x1000>;
+		L12: spi at 20004000 {
+			compatible = "sifive,spi0";
+			interrupts = <6>;
+			reg = <0x20004000 0x1000 0x40000000 0x20000000>;
+			reg-names = "control", "mem";
+		L7: teststatus at 4000 {
+			compatible = "sifive,test0";
+			reg = <0x4000 0x1000>;
diff --git a/bsps/riscv/riscv/include/bsp/fe310-uart.h b/bsps/riscv/riscv/include/bsp/fe310-uart.h
index 0000000000..c6c6fcb876
--- /dev/null
+++ b/bsps/riscv/riscv/include/bsp/fe310-uart.h
@@ -0,0 +1,61 @@
+ * Copyright (C) 2019 Pragnesh Patel <pragnesh.patel at sifive.com>
+ * are met:
+#ifndef FE310_UART_H
+#define FE310_UART_H
+#define TXRXREADY (1 << 31)
+#include <rtems/termiostypes.h>
+#include <rtems/irq.h>
+typedef struct {
+  uint32_t txdata;
+  uint32_t rxdata;
+  uint32_t txctrl;
+  uint32_t rxctrl;
+  uint32_t ie;
+  uint32_t ip;
+  uint32_t div;
+} fe310_uart_t;
+/* Low-level driver specific data structure */
+typedef struct {
+  rtems_termios_device_context base;
+  const char *device_name;
+  volatile fe310_uart_t *regs;
+} fe310_uart_context;
+int fe310_uart_read(rtems_termios_device_context *base);
+void fe310_console_putchar(rtems_termios_device_context * context,char c);
+extern const rtems_termios_device_handler fe310_uart_handler;
+extern fe310_uart_context driver_context;
+#endif /* FE310_UART_H */
diff --git a/bsps/riscv/riscv/include/bsp/riscv.h b/bsps/riscv/riscv/include/bsp/riscv.h
index 374d5f7a77..f2f1a597ca 100644
--- a/bsps/riscv/riscv/include/bsp/riscv.h
+++ b/bsps/riscv/riscv/include/bsp/riscv.h
@@ -38,6 +38,10 @@ extern volatile RISCV_CLINT_regs *riscv_clint;
 void *riscv_fdt_get_address(const void *fdt, int node);
+uint32_t riscv_get_core_frequency(void);
+#endif
 #ifdef RTEMS_SMP
 extern uint32_t riscv_hart_count;
 #else
diff --git a/bsps/riscv/riscv/start/bspstart.c b/bsps/riscv/riscv/start/bspstart.c
index d4c4e1ff7f..a462bbe6e1 100644
--- a/bsps/riscv/riscv/start/bspstart.c
+++ b/bsps/riscv/riscv/start/bspstart.c
@@ -30,6 +30,11 @@
 #include <libfdt.h>
+#include <string.h>
+unsigned int riscv_core_freq;
+#endif
@@ -161,8 +166,55 @@ uint32_t riscv_get_hart_index_by_phandle(uint32_t phandle)
   return UINT32_MAX;
+static uint32_t get_core_frequency(void)
+	uint32_t node;
+	const char *fdt=bsp_fdt_get();
+  char *tlclk;
+	uint32_t len;
+  do
+    node=fdt_node_offset_by_compatible(fdt, -1,"fixed-clock");
+    uint32_t *val=NULL;
+    if (node>0)
+      tlclk = fdt_getprop(fdt, node, "clock-output-names", &len);
+      if (strcmp(tlclk,"tlclk") == 0)
+        val = fdt_getprop(fdt, node, "clock-frequency", &len);
+		    if(val !=NULL)
+			    riscv_core_freq=fdt32_to_cpu(*val);
+          break;
+	  }else
+      bsp_fatal(RISCV_FATAL_NO_TLCLOCK_FREQUENCY_IN_DEVICE_TREE);
+  } while (node > 0);
+	return riscv_core_freq;
+inline uint32_t riscv_get_core_frequency(void)
+#endif
 void bsp_start(void)
   riscv_find_harts();
   bsp_interrupt_initialize();
+	riscv_core_freq=get_core_frequency();
+#endif
diff --git a/c/src/lib/libbsp/riscv/riscv/Makefile.am b/c/src/lib/libbsp/riscv/riscv/Makefile.am
index 34bedf844f..15b0865306 100644
--- a/c/src/lib/libbsp/riscv/riscv/Makefile.am
+++ b/c/src/lib/libbsp/riscv/riscv/Makefile.am
@@ -46,7 +46,11 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-defa
 librtemsbsp_a_SOURCES +=../../../../../../bsps/riscv/riscv/clock/clockdrv.c
 # Timer
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-cpucounter.c
+#else
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-stub.c
+#endif
 # IRQ
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
@@ -60,6 +64,10 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termio
 librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/console/console-config.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/console/htif.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/console/fe310-uart.c
+#endif
 if HAS_SMP
 librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/start/bspsmp.c
 endif
diff --git a/c/src/lib/libbsp/riscv/riscv/configure.ac b/c/src/lib/libbsp/riscv/riscv/configure.ac
index b01dee242e..26a3e07e98 100644
--- a/c/src/lib/libbsp/riscv/riscv/configure.ac
+++ b/c/src/lib/libbsp/riscv/riscv/configure.ac
@@ -36,9 +36,14 @@ RTEMS_BSPOPTS_HELP([RISCV_MAXIMUM_EXTERNAL_INTERRUPTS],[maximum number of extern
 RTEMS_BSPOPTS_SET([RISCV_ENABLE_HTIF_SUPPORT],[*],[])
 RTEMS_BSPOPTS_HELP([RISCV_ENABLE_HTIF_SUPPORT],[enables the HTIF support if defined to a non-zero value, otherwise it is disabled (disabled by default)])
+RTEMS_BSPOPTS_SET([RISCV_CONSOLE_MAX_NS16550_DEVICES],[frdme310arty*],[])
 RTEMS_BSPOPTS_SET([RISCV_CONSOLE_MAX_NS16550_DEVICES],[*],[2])
 RTEMS_BSPOPTS_HELP([RISCV_CONSOLE_MAX_NS16550_DEVICES],[maximum number of NS16550 devices supported by the console driver (2 by default)])
+RTEMS_BSPOPTS_SET([RISCV_ENABLE_FRDME310ARTY_SUPPORT],[frdme310arty*],[1])
+RTEMS_BSPOPTS_SET([RISCV_ENABLE_FRDME310ARTY_SUPPORT],[*],[])
+RTEMS_BSPOPTS_HELP([RISCV_ENABLE_FRDME310ARTY_SUPPORT],[enables support sifive Freedom E310 Arty board if defined to a non-zero value,otherwise it is disabled (disabled by default)])
 RTEMS_BSP_CLEANUP_OPTIONS
 case "${RTEMS_BSP}" in
@@ -53,13 +58,22 @@ case "${RTEMS_BSP}" in
 esac
+case "${RTEMS_BSP}" in
+  frdm*310arty)
+    RISCV_RAM_REGION_SIZE_DEFAULT=0x10000000
+    RISCV_RAM_REGION_SIZE_DEFAULT=0x04000000
+esac
 AC_DEFUN([RISCV_LINKCMD],[
 AC_ARG_VAR([$1],[$2])dnl
 [$1]=[$]{[$1]:-[$3]}
 RISCV_LINKCMD([RISCV_RAM_REGION_BEGIN],[begin of the RAM region for linker command file (default is 0x70000000 for 64-bit with -mcmodel=medlow and 0x80000000 for all other)],[${RISCV_RAM_REGION_BEGIN_DEFAULT}])
-RISCV_LINKCMD([RISCV_RAM_REGION_SIZE],[size of the RAM region for linker command file (default 64MiB)],[0x04000000])
+RISCV_LINKCMD([RISCV_RAM_REGION_SIZE],[size of the RAM region for linker command file (default is 256 MiB for frdme310arty and 64 MiB for all other)],[${RISCV_RAM_REGION_SIZE_DEFAULT}])
 AC_CONFIG_FILES([
 Makefile
2.17.1
