Doorstop and UIDs with names instead of numbers
Wed Oct 23 05:55:47 UTC 2019
Hello,
Doorstop is the proposed tool to do the future requirements and
specification management in RTEMS:
https://doorstop.readthedocs.io/en/latest/
Each item (e.g. requirement) has an UID:
https://doorstop.readthedocs.io/en/latest/reference/item/
"The UID of an item is defined by its file name without the extension.
An UID consists of two parts, the prefix and a number. The parts are
divided by an optional separator. The prefix is determined by the
document to which the item belongs. The number is automatically assigned
by Doorstop."
These numbers turned out to be a bit painful to work with. I added a
feature request to Doorstop to optionally use a name instead of a number:
https://github.com/doorstop-dev/doorstop/issues/349
It would be good to get a bit of support in this issue if you would like
to avoid using hundreds of magic numbers in the future.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
