How to add a dependency on start.o to the test executables in waf?
    Sebastian Huber
    Fri Oct 25 05:26:10 UTC 2019
On 25/10/2019 07:18, Sebastian Huber wrote:
>>> How can I add a dependency on start.o to the test executables? I
>>> tried several
>>> variants of bld.add_manual_dependency(), but nothing worked.
>> I am not sure, I would need to have a close look at how the test stuff
>> is being
>> put together. I cannot see where start.o in the bld statement.
>> Is start.o treated in a special way, maybe hidden when linking in the
>> linker
>> command?
> The start.o is a start file and not a normal object. It is added either
> through the GCC specs or the linker command file STARTUP() directive.
The dependency tracking for start.o is a nice to have feature. The
current build system also lacks support for it.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
