How to add a dependency on start.o to the test executables in waf?
Sebastian Huber
Fri Oct 25 05:18:57 UTC 2019
On 25/10/2019 03:41, Chris Johns wrote:
> On 25/10/19 12:12 am, Sebastian Huber wrote:
>> Hello,
>> I have a problem in the new build system, which I am not able to solve with my
>> novice waf knowledge.
>> You can check out the prototype with these steps:
>> git clone git://git.rtems.org/sebh/rtems.git
>> cd rtems
>> git checkout --track origin/build
>> ./waf bsp_defaults --rtems-bsps=sparc > bsps.ini
>> ./waf configure
> I uses ...
> ./waf configure --rtems-tools=/opt/work/rtems/5
>> ./waf
> Nice, it took 6.944s to build.
>> To build a test executable, we need:
>> 1. the test program objects,
>> 2. the libraries, e.g. librtemscpu.a and librtemsbsp.a
>> 3. the linker command file (source or configuration file, see ConfigFileItem in
>> wscript)
>> 4. the start file start.o
>> The dependencies on 1. and 2. work. The 3. is basically read-only for a build.
>> The problem is 4.
>> The start file is build with:
>> class StartItem(Item):
>> def __init__(self, uid, data):
>> super(StartItem, self).__init__(uid, data)
>> def build(self, bld):
>> bld(
>> rule="${CC} -DASM ${CFLAGS} ${CPPFLAGS} ${DEFINES_ST:DEFINES}
>> ${CPPPATH_ST:INCPATHS} -c -o ${TGT} ${SRC}",
>> source=self.data["source"],
>> target=self.data["target"],
>> name=self.uid,
>> features="asm",
>> includes=bld.env.INCLUDES,
>> before=["cstlib"],
> Why the need for the rule?
https://lists.rtems.org/pipermail/devel/2019-October/055771.html
Actually, I don't understand this stuff good enough. It would be nice I
we could use the standard asm rule:
https://gitlab.com/ita1024/waf/blob/master/waflib/Tools/asm.py#L59
However, when I remove the rule, then start.o is not built.
>> The test executables are built with:
>> class ExecutableItem(Item):
>> super(ExecutableItem, self).__init__(uid, data)
>> executables.append(self)
>> if self.is_enabled(bld):
>> includes = bld.env["INCLUDES"]
>> bld.env["INCLUDES"] = (
>> includes + bld.bsp_includes + ["testsuites/support/include"]
>> bld.use = ["rtemstest", "rtemscpu", "rtemsbsp"]
>> for p in self.links():
>> p.build(bld)
>> bld.env["INCLUDES"] = includes
>> bld(
>> target=self.data["target"] + ".exe",
>> use=bld.use,
>> features="c cprogram",
>> del bld.use
> del ? If there is an active reference it will not be deleted. Python likes to share.
This will change. I will probably move to a parameter passed to build().
>> How can I add a dependency on start.o to the test executables? I tried several
>> variants of bld.add_manual_dependency(), but nothing worked.
> I am not sure, I would need to have a close look at how the test stuff is being
> put together. I cannot see where start.o in the bld statement.
> Is start.o treated in a special way, maybe hidden when linking in the linker
> command?
The start.o is a start file and not a normal object. It is added either
through the GCC specs or the linker command file STARTUP() directive.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
