Lots of BSP Build Failures
Sat Oct 26 17:54:16 UTC 2019
Hi
I have been trying to build up a script which tests as much as possible. I
have had enough script and tool build issues to not look at results much.
But this will need attention and help:
https://lists.rtems.org/pipermail/build/2019-October/007654.html
The gdb arm sim bsp has outlived its usefulness so killing it will
eliminate some failures but there are a LOT of failures in that report.
Help is appreciated investigating and fixing.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191026/cf0e42c9/attachment.html>
