RFC: Building RTEMS/RISC-V with LLVM/Clang
Hesham Almatary hesham.almatary at cl.cam.ac.uk
Mon Oct 28 13:51:36 UTC 2019
On Mon, 28 Oct 2019 at 10:33, Sebastian Huber
> On 28/10/2019 11:16, Hesham Almatary wrote:
> > Hi Sebastian,
> > The *_clang ones aren't expected to be compiled by GCC (and the native
> > *.cfg won't compile with clang). Is there a reason they should be?
> You can build all BSPs of an architecture with:
> ../configure --target=riscv-rtems5
> This no longer works on riscv.
Right, I haven't tested on that level. I'm not sure what's the right
way to do that in configure.ac. Do you've a quick solution in mind? I
can delete the *_clang.cfg files until we figure it out.
