[PATCH v2] [rsb] Update Spike build
Joel Sherrill
joel at rtems.org
Mon Oct 28 23:15:12 UTC 2019
On Mon, Oct 28, 2019 at 5:20 AM Hesham Almatary <
hesham.almatary at cl.cam.ac.uk> wrote:
> On Mon, 28 Oct 2019 at 04:01, Chris Johns <chrisj at rtems.org> wrote:
> > On 28/10/19 9:21 am, Hesham Almatary wrote:
> > > On Sun, 27 Oct 2019 at 20:54, Chris Johns <chrisj at rtems.org
> > > <mailto:chrisj at rtems.org>> wrote:
> > > On 27/10/19 9:37 pm, Hesham Almatary wrote:
> > > > Yeah fesvr is now part of Spike in-tree. I didn't like it had to
> be
> > > > built separately either [1].
> > > > Joel, AFAIR, dtc was always needed.
> > > Please have the package build FDT if it is needed. Do no rely on
> it being
> > > installed as some hosts do not have a package to install.
> > > I think Joel has already added it
> https://github.com/RTEMS/rtems-source-builder/blob/master/bare/config/devel/spike.bset#L7
> > Thanks.
> > The config file has some issues. I am fixing the %hash issues. Is the
> patch
> > still needed if the version used has the fix?
> The version that has the fix is a recent one, and it has fesvr in its
> source tree, hence, there's no separate fesvr any more. The patch will
> still be needed to get rid of the separate fesvr build for this recent
> Spike revision.
If you are bumping to a version which doesn't need my patch, great!
Is this all pushed now?
> > Chris
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191028/874f5fbc/attachment.html>
