ARM BSP build failure.
Wed Oct 30 08:17:44 UTC 2019
On 30/10/2019 07:18, Chris Johns wrote:
> Hi,
> Building all ARM BSPs on master today I get ...
> checking for arm-rtems5-gcc... (cached) arm-rtems5-gcc
> checking whether the C compiler works... no
> configure: error: in
> `/opt/work/chris/rtems/kernel/bsps/arm/arm-rtems5/c/lpc40xx_ea_ram':
> configure: error: C compiler cannot create executables
> See `config.log' for more details
> gmake[2]: *** [Makefile:1064: lpc40xx_ea_ram] Error 1
> gmake[2]: Leaving directory '/opt/work/chris/rtems/kernel/bsps/arm/arm-rtems5/c'
> gmake[1]: *** [Makefile:289: all-recursive] Error 1
> gmake[1]: Leaving directory '/opt/work/chris/rtems/kernel/bsps/arm/arm-rtems5/c'
> Is the lpc40xx_ea_ram BSP OK?
I built all BSPs this week, however, with an older tool chain. What do
you see in the config.log?
This looks like a tool chain bug.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
