[PATCH 2/4] bare/pcre: Add PCRE 8.40
chrisj at rtems.org chrisj at rtems.org
Sun Sep 15 02:58:39 UTC 2019
 bare/config/devel/pcre-8.40-1.cfg  | 19 ++++++++
 source-builder/config/pcre-8-1.cfg | 70 ++++++++++++++++++++++++++++++
 2 files changed, 89 insertions(+)
 create mode 100644 bare/config/devel/pcre-8.40-1.cfg
 create mode 100644 source-builder/config/pcre-8-1.cfg
diff --git a/bare/config/devel/pcre-8.40-1.cfg b/bare/config/devel/pcre-8.40-1.cfg
new file mode 100644
index 0000000..8627260
--- /dev/null
+++ b/bare/config/devel/pcre-8.40-1.cfg
@@ -0,0 +1,19 @@
+# PCRE
+%if %{release} == %{nil}
+%define release 1
+%endif
+%include %{_configdir}/base.cfg
+%define pcre_version 8.40
+%hash sha512 pcre-%{pcre_version}.tar.bz2 tMJ+r73zO9ehOEZVsZNvS+O8Z0XAcjR+sm6YiJbFJmS9haxCRE2hvni24g9Ftsflkh9fIPWwdBtb09mETlvU4g==
+# The PCRE build instructions. We use 8.x Release 1.
+%ifn %{pkgconfig check pcre}
+ %include %{_configdir}/pcre-8-1.cfg
+%endif
diff --git a/source-builder/config/pcre-8-1.cfg b/source-builder/config/pcre-8-1.cfg
index 0000000..461967f
--- /dev/null
+++ b/source-builder/config/pcre-8-1.cfg
@@ -0,0 +1,70 @@
+# PCRE - Perl Compatible Regular Expressions 0.x.x Version 1.
+# This configuration file configure's, make's and install's pcre.
+%define release 1
+%endif
+Name:      pcre-%{pcre_version}-%{_host}-%{release}
+Summary:   The PCRE library is a set of functions that implement regular
+           expression pattern matching using the same syntax and semantics
+	   as Perl 5.
+Version:   %{pcre_version}
+Release:   %{release}
+URL: 	   http://pcre.org/
+BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
+# Source
+%source set pcre https://ftp.pcre.org/pub/pcre/pcre-%{pcre_version}.tar.bz2
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  source_dir_pcre="pcre-%{pcre_version}"
+  %source setup pcre -q -n pcre-%{pcre_version}
+  %patch setup pcre -p1
+  cd ${build_top}
+%build
+  build_top=$(pwd)
+  %{build_directory}
+  mkdir -p ${build_dir}
+  cd ${build_dir}
+  %{host_build_flags}
+  ../${source_dir_pcre}/configure \
+    --prefix=%{_prefix} \
+    --bindir=%{_bindir} \
+    --exec_prefix=%{_exec_prefix} \
+    --includedir=%{_includedir} \
+    --libdir=%{_libdir} \
+    --libexecdir=%{_libexecdir} \
+    --mandir=%{_mandir} \
+    --infodir=%{_infodir} \
+    --datadir=%{_datadir} \
+    --build=%{_build} --host=%{_host}
+  %{__make} %{?_smp_mflags} all
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  %{__rmdir} $SB_BUILD_ROOT
+  cd ${build_dir}
+  %{__make} DESTDIR=$SB_BUILD_ROOT install
+  cd ${build_top}
2.20.1
