[PATCH 1/4] sb/check-command: Add a check command wrapper
chrisj at rtems.org chrisj at rtems.org
Sun Sep 15 02:58:38 UTC 2019
 source-builder/sb/rtems-check-command | 26 ++++++++++++++++++++++++++
 1 file changed, 26 insertions(+)
 create mode 100755 source-builder/sb/rtems-check-command
diff --git a/source-builder/sb/rtems-check-command b/source-builder/sb/rtems-check-command
new file mode 100755
index 0000000..1cbe5c9
--- /dev/null
+++ b/source-builder/sb/rtems-check-command
@@ -0,0 +1,26 @@
+#! /bin/sh
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2019 Chris Johns (chrisj at rtems.org)
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Permission to use, copy, modify, and/or distribute this software for any
+# purpose with or without fee is hereby granted, provided that the above
+# copyright notice and this permission notice appear in all copies.
+# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+# Check is a command exists
+set +e
+command -v $*
+exit 0
2.20.1
