LLVM on openSUSE 15.1
Tue Sep 17 06:14:35 UTC 2019
On 17/9/19 4:07 pm, Sebastian Huber wrote:
> On 17/09/2019 08:07, Chris Johns wrote:
>> On 17/9/19 3:32 pm, Sebastian Huber wrote:
>>> Hello,
>>> I didn't get far:
>>> config.status: creating t/wrap/automake-1.12
>>> + make -j 12 all
>>>    GEN      automake
>>>    GEN      aclocal
>>>    GEN      t/ax/shell-no-trail-bslash
>>>    GEN      doc/aclocal.1
>>>    GEN      doc/automake.1
>>>    GEN      runtest
>>>    GEN      t/ax/test-defs.sh
>>>    GEN      lib/Automake/Config.pm
>>>    GEN      doc/aclocal-1.12.1
>>>    GEN      doc/automake-1.12.1
>>> help2man: can't get `--help' info from automake-1.12
>>> Try `--no-discard-stderr' if option outputs to stderr
>>> make: *** [Makefile:4114: doc/automake-1.12.1] Error 255
>> That is weird because this is what we build for gcc as we need autoconf to boot
>> strap RTEMS.
> This is indeed quite weird, I never had problems building automake before. I
> will try to figure out what went wrong here.
It is the internal build and so could be a little different.
