LLVM on openSUSE 15.1
Wed Sep 18 05:40:50 UTC 2019
On 18/9/19 3:36 pm, Sebastian Huber wrote:
> On 17/09/2019 08:07, Sebastian Huber wrote:
>> On 17/09/2019 08:07, Chris Johns wrote:
>>> On 17/9/19 3:32 pm, Sebastian Huber wrote:
>>>> Hello,
>>>> I didn't get far:
>>>> config.status: creating t/wrap/automake-1.12
>>>> + make -j 12 all
>>>>    GEN      automake
>>>>    GEN      aclocal
>>>>    GEN      t/ax/shell-no-trail-bslash
>>>>    GEN      doc/aclocal.1
>>>>    GEN      doc/automake.1
>>>>    GEN      runtest
>>>>    GEN      t/ax/test-defs.sh
>>>>    GEN      lib/Automake/Config.pm
>>>>    GEN      doc/aclocal-1.12.1
>>>>    GEN      doc/automake-1.12.1
>>>> help2man: can't get `--help' info from automake-1.12
>>>> Try `--no-discard-stderr' if option outputs to stderr
>>>> make: *** [Makefile:4114: doc/automake-1.12.1] Error 255
>>> That is weird because this is what we build for gcc as we need autoconf to boot
>>> strap RTEMS.
>> This is indeed quite weird, I never had problems building automake before. I
>> will try to figure out what went wrong here.
> We have configuration files for Automake 1.12.6. I fixed it like this:
> https://git.rtems.org/rtems-source-builder/commit/?id=bf7b4ad68f0faa9a35e52ca1baafb6f72c0fb673
Thanks.
