[PATCH v2] bsps/beagle: register i2c device at initialization
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Wed Sep 18 19:18:17 UTC 2019
 bsps/arm/beagle/i2c/bbb-i2c.c     |  6 +++---
 bsps/arm/beagle/include/bsp/i2c.h | 10 ----------
 bsps/arm/beagle/start/bspstart.c  | 16 ++++++++++++++++
 3 files changed, 19 insertions(+), 13 deletions(-)
diff --git a/bsps/arm/beagle/i2c/bbb-i2c.c b/bsps/arm/beagle/i2c/bbb-i2c.c
index 37b88864b9..f705078085 100644
--- a/bsps/arm/beagle/i2c/bbb-i2c.c
+++ b/bsps/arm/beagle/i2c/bbb-i2c.c
@@ -186,16 +186,16 @@ static int am335x_i2c_reset( bbb_i2c_bus *bus )
   bus->con_reg = 0;
   regs->BBB_I2C_CON = bus->con_reg;
-  udelay( 50000 );
+  rtems_counter_delay_nanoseconds(50000000);
   regs->BBB_I2C_SYSC = AM335X_I2C_SYSC_SRST;
-  udelay( 1000 );
+  rtems_counter_delay_nanoseconds(1000000);
   regs->BBB_I2C_CON = AM335X_I2C_CON_I2C_EN;
   while ( !( regs->BBB_I2C_SYSS & AM335X_I2C_SYSS_RDONE )
           && timeout >= 0 ) {
     --timeout;
-    udelay( 100 );
+  rtems_counter_delay_nanoseconds(100000);
   if ( timeout <= 0 ) {
diff --git a/bsps/arm/beagle/include/bsp/i2c.h b/bsps/arm/beagle/include/bsp/i2c.h
index 9d253406bf..60f71194bf 100644
--- a/bsps/arm/beagle/include/bsp/i2c.h
+++ b/bsps/arm/beagle/include/bsp/i2c.h
@@ -94,16 +94,6 @@ int am335x_i2c_bus_register(
   rtems_vector_number irq
-static inline int bbb_register_i2c_0( void )
-  return am335x_i2c_bus_register(
-    BBB_I2C_0_BUS_PATH,
-    AM335X_I2C0_BASE,
-    I2C_BUS_CLOCK_DEFAULT,
-    BBB_I2C0_IRQ
 static inline int bbb_register_i2c_1( void )
diff --git a/bsps/arm/beagle/start/bspstart.c b/bsps/arm/beagle/start/bspstart.c
index 224f9ecf3b..8112e0867d 100644
--- a/bsps/arm/beagle/start/bspstart.c
+++ b/bsps/arm/beagle/start/bspstart.c
@@ -17,6 +17,8 @@
 #include <bsp/irq-generic.h>
 #include <bsp/fdt.h>
 #include <bsp/linker-symbols.h>
+#include <bsp/i2c.h>
+#include <rtems/sysinit.h>
 #include "bspdebug.h"
@@ -41,3 +43,17 @@ uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
   return intr[0];
+static void bbb_i2c_0_initialize(void)
+  am335x_i2c_bus_register(BBB_I2C_0_BUS_PATH,
+                          AM335X_I2C0_BASE,
+                          I2C_BUS_CLOCK_DEFAULT,
+                          BBB_I2C0_IRQ);
+RTEMS_SYSINIT_ITEM(
+  bbb_i2c_0_initialize,
+  RTEMS_SYSINIT_LAST,
+  RTEMS_SYSINIT_ORDER_LAST
2.20.1
