[PATCH rtems_waf] rtems.py: Fix typo
Chris Johns
chrisj at rtems.org
Wed Sep 18 22:28:53 UTC 2019
Pushed.
Thanks
On 19/9/19 4:14 am, Vijay Kumar Banerjee wrote:
> rtems.py | 4 ++--
> 1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/rtems.py b/rtems.py
> index 2e57de4..af4b5fd 100644
> --- a/rtems.py
> +++ b/rtems.py
> @@ -326,7 +326,7 @@ def check_cc(conf, *k, **kw):
> kw['fragment'] = test_application()
> conf.check_cc(*k, **kw)
> -def check_lib_path(ctx, lib, libpath = [], manditory = True):
> +def check_lib_path(ctx, lib, libpath = [], mandatory = True):
> lib_lib = 'lib%s.a' % (lib)
> ctx.start_msg('Library %s' % (lib_lib))
> cmd = '%s %s %s -print-file-name=%s' % (' '.join(ctx.env.CC),
> @@ -336,7 +336,7 @@ def check_lib_path(ctx, lib, libpath = [], manditory = True):
> out = ctx.cmd_and_log(cmd)
> out = os.path.normpath(out.strip())
> if out == lib_lib:
> - if manditory:
> + if mandatory:
> ctx.fatal('The library %s not found' % (lib_lib))
> ctx.end_msg('not found')
> else:
