libbsd build problem on powerpc
Fri Sep 20 07:38:52 UTC 2019
Hello,
I get the following build error on powerpc with the libbsd:
/scratch/git-rtems-libbsd (5-freebsd-12) > ./waf -j 1
Waf: Entering directory
`/scratch/git-rtems-libbsd/build/powerpc-rtems5-qoriq_e500-default'
[1794/1909] Linking build/powerpc-rtems5-qoriq_e500-default/debugger01.exe
/build/rtems/5/lib/gcc/powerpc-rtems5/7.4.1/../../../../powerpc-rtems5/bin/ld:
cannot find -ldebugger
collect2: error: ld returned 1 exit status
Waf: Leaving directory
Build failed
  -> task in 'debugger01.exe' failed with exit status 1 (run with -v to
display more information)
I tried to understand how the TestIfHeaderComposer() works, but I did't
figure out what the purpose of the "define_keys" is.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
