rtems-tester initial port getting "'NoneType' object is not iterable"
Sat Sep 21 01:43:29 UTC 2019
On Fri, Sep 20, 2019, 8:21 PM Chris Johns <chrisj at rtems.org> wrote:
> On 21/9/19 5:56 am, dufault at hda.com wrote:
> > One thing I should have said is that “rtems" and "rtems-tester" are the
> master branches, "rtems-tester" is updated as of yesterday, and “rtems” is
> recent.
> Thanks.
> >> On Sep 20, 2019, at 15:46 , Peter Dufault <dufault at hda.com> wrote:
> >> I’m bringing up the rtems-tester for the PowerPC “beatnik” bsp.  I’m
> impressed with how easy it is to implement (well done, Chris).
> Thanks, it is good to get this type of feedback and things are just
> working.
> > But after doing all the easy work, and just as I thought my initial run
> of the “samples" was about to exit successfully, the script faulted and
> gave me the error "TypeError: 'NoneType' object is not iterable”.  I’ve
> pasted the output of my run below.
> OK.
> >> Average test time: 0:00:40.583694
> Does this target take a bit of time to boot?
> >> Testing time     : 0:09:28.171711
> >> Traceback (most recent call last):
> >>  File "../rtems-tools/tester/rt/cmd-test.py", line 42, in <module>
> >>    test.run(sys.argv[1:], command_path = base)
> >>  File "/home/dufault/development/rtems/rtems-tools/tester/rt/test.py",
> line 455, in run
> >>    for report_format in report_formats:
> This is from Kinsey patch where report formats was added....
> https://git.rtems.org/rtems-tools/commit/?id=5fcaf843bdb491e2da14dc1af61806ac6d20bae5
> Joel?
Sorry I was traveling home today. I have good news to pass along later.
I will get Kinsey to look at this. Peter can you email us the configuration
file?
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190920/02602b87/attachment-0002.html>
